Awesome - I've wanted to do this for a while. If you are able to show your wiring hookups I would really appreciate it. I'm not very comfortable with electrical.Today installed footwell lights and hooked them as Ambient lights, didn't use VGA or anything. Photos coming soon.
So is this able to be done on an SE model as well?If you want to hook them up to the computer so you can set the brightness in the MFI they go to pin T52b/50 on the Body Control Module
-J
the rear go into little rectangle holes under the front seat..Mine are hooked up to the front cigarette lighter. Brown wire is ground and Grey wire is positive for light. Now I can control them from dimmer.
I bought 4 lights wanted to put 2 in rear but can't find any place to put them in rear.
Is it in the black circular part? If it is there is foam behind it.the rear go into little rectangle holes under the front seat..
from the back seat: locate the center of the front seat back, not follow that down to the bottom section, now keep going and it's right under the bottom of the front seat back.. clear as mud yet?
Thanksthere is foam behind it, but i'll take a pic tomorrow for you.
Can you post a link to DIY. ThanksThere is a DIY that I posted, I hooked mine up to the cigarette lighter and bought my lights from bold sport.
Search footwell it will come.Can you post a link to DIY. Thanks
