Old September 21st, 2018, 23:39   #16
[486]
TDI(s): 02 golf ALH
I did one with a hammer and chisel like you would a fan clutch
didn't seal too good on the steel-steel part after that, had to introduce a copper washer in there to get it running again, was interesting in that I could get fuel at the line nuts, but nothing out of the injectors
when the new one showed up, milled the three flats onto it to fit a 15/16 socket like they shoulda from the factory
[486] is online now   Reply With Quote
Old September 22nd, 2018, 08:25   #17
WildChild80
WildChild80's Avatar
I had thought about that but I have 3 and not sure if I want that much fun in my life.
But on another note, I stretched the old o-ring and I could see the really fine cracks in it.
The leak came on when I let the car set for a week or so. I let the other Jetta set for about 2 months and the decoupler wasn't holding. I'm seeing a pattern of I shouldn't let one sit for too long.
WildChild80 is offline   Reply With Quote
LF: 30 mm 12 point axle socket daniel_mad Ontario 7 November 27th, 2017 10:38
FS: 30mm 12 Point Impact Socket 1/2-Inch Drive. Sunex 230zm For Wheel Bearing Nut. TdiTaff Private TDI Items for Sale/Wanted 0 August 15th, 2016 21:24
12 point socket GuyGuy TDI 101 11 June 29th, 2006 07:37
Looking for a 1/2" Six Point Metric Socket Set VelvetFoot TDI 101 12 April 11th, 2004 21:14
Multi point socket - Steering wheel removal djdluck TDI 101 7 February 26th, 2004 20:22
Page generated in 0.13054 seconds with 12 queries
[Output: 54.47 Kb. compressed to 50.38 Kb. by saving 4.09 Kb. (7.50%)]
