Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old March 23rd, 2019, 13:59   #1
hwork1
Default 2013 Touareg transmission service
Have 71,000 miles on mine, anyone completed a fluid and filter change on one of these? A quick search scared me a tad as I ended up empty handed.
hwork1 is offline   Reply With Quote
Old March 24th, 2019, 14:45   #2
TrdLtly
This is the approach I plan to take: T3 Trans Flush
TrdLtly is offline   Reply With Quote
Old March 24th, 2019, 21:26   #3
hwork1
Thank you, looks interesting.
Old March 25th, 2019, 04:33   #4
oilhammer's Avatar
Fuel Economy: fantastic
We use a machine here, however many newer transmissions (including these 8sp Aisins) have a thermostat in the ATF preheater (the little "box" on the top of the unit with coolant pipes going to and from) that will not allow ATF flow through the cooler until the ATF is good and hot.... which sitting still they often never achieve.
I would just drain and fill it from the drain/fill hole in the pan. You'll only get about 4 liters doing it that way, which is why if it looks really dark you can do it a couple times within a hundred miles or so. Total fill is closer to 11 liters, FYI.
You needn't mess with the filter, it won't have anything in it.
Find a source for Idemitsu TLS fluid, no sense in spending some obscene amount of money for VW-branded ATF for your T'reg's Toyota transmission. They just repackage it. You can often find a 5q bottle on Amazon for about $30. 5 L of the VW branded stuff I just found on eBay for $110.
We've been using Idemitsu fluids in every Aisin box that comes through our doors for decades, never had any issues. This includes [obviously] all the Toyota products, as well as all the Volvos, Jeeps, GM, Ford, Mitsubishi, Nissan, ChryCo, Mini, etc. that use them.
www.cardocautomotive.com
Old March 25th, 2019, 08:27   #5
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Oilhammer, do the newer boxes use a WS fluid, not T-IV? I assumed the newer boxes would use the newer WS standard.
-J
Present:
2018 Tesla Model 3 DM. 47,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 28,000 miles.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old March 25th, 2019, 08:35   #6
oilhammer's Avatar
Idemitsu TLS-LV is WS compliant, and is backwards compatible with the T-IV.
We have not used the "old" stuff in quite a while. The only real difference is the LV (low viscosity) flows better when it is super cold. At least, that is what they told us at Toyota school.
Old March 26th, 2019, 14:40   #7
TrdLtly
Great info OilHammer. Thank you for your input. Just ordered 2 five quart jugs of the Idemitsu off Amazon. My '14 has 62k mi on it. It is time. Dealer said something like $600+ them to do it. Told me to do it myself instead. I said absolutely.
Old March 31st, 2019, 13:06   #8
bizzle
bizzle's Avatar
Oh I'm going to try this oil out. The big T3 trans flush thread didn't come up with any suitable alternative and the best price I was able to get was $20/qt from the dealer.
A few weeks ago someone described the best way to get oil analyses for the best price?
Does anyone remember or have recommendation for best pricing on used oil analysis?
bizzle is online now   Reply With Quote
Old March 31st, 2019, 14:37   #9
TrdLtly
For clarification: Oil or Fluid? This is a thread about "Transmission Service" which would be about fluid. Not oil. Transmission "Fluid" can be analyzed. My experience has only been with Blackstone
Old April 2nd, 2019, 13:35   #10
compu_85
Gadget Guy
compu_85's Avatar
Transmission fluid is basically oil + additives + red dye. Blackstone can analyse trans fluid, too.
Old April 2nd, 2019, 14:29   #11
oilhammer's Avatar
Except some is gold, some is blue, some is green....
Old April 3rd, 2019, 16:47   #12
DieselGator
Wow great information here! Great advice on fluid, I was planning at doing a drain/drop pan/clean magnets/replace filter/gasket/refill at 100k miles -no towing.
This:
"You needn't mess with the filter, it won't have anything in it."
is surprising to me?
really no need to change the filter? even in my case at 100k?
if just draining and refilling are enough that would be great.
DieselGator is offline   Reply With Quote
Old December 1st, 2019, 14:08   #13
bizzle
bizzle's Avatar
What do you all think about using Liquid Moly Top Tec 1800
https://pim.liqui-moly.de/pidoc/P000...00-71.0-en.pdf
or
Halvoline DEXRON-VI Multi-Vehicle Synthetic Automatic Transmission Fluid
https://cglapps.chevron.com/sdspds/P...&docFormat=PDF
What else do I need for towing on my 2013 Touareg?? javijavit VW Touareg TDIs 5 July 21st, 2016 07:50
2013 Q7, related to which Touareg? da.hs Audi SUVs (Q7 & Q5) and other V6 TDIs 2 April 15th, 2016 22:49
2013 Touareg TDi purchase ccbsecu VW Touareg TDIs 5 July 20th, 2015 20:58
2013 TDI Touareg Mike3pedals VW Touareg TDIs 0 February 20th, 2015 05:28
2013 40k service notes (trans, oil, fuel service) JAYFARMLAW VW Passat Family (NMS and B7) TDIs (2012+) 15 February 20th, 2014 05:11
Page generated in 0.15425 seconds with 12 queries
[Output: 116.90 Kb. compressed to 98.60 Kb. by saving 18.30 Kb. (15.65%)]
