Old August 14th, 2018, 06:09   #1
jbourke367
Default oil cap: vented or not?
Hi All,
I have a slow leak coming from my oil cap. Therefore, I will be replacing the oil cap. There are vented oil caps as well as non vented. Which one do I want? What is the advantage/disadvantage of each?
jbourke367 is offline   Reply With Quote
Old August 14th, 2018, 06:18   #2
ktmkris
I have had 4 tdi’s and all of them have done that. Once I vented the crank case pressure hose to atmosphere “ccv mod” the oil leak at the caps stopped. Second side effect of venting ccv to atmosphere is no more oil in intake, intercooler or charge pipes.
Turbo cars have higher crank case pressure which is why these cars do that.
ktmkris is offline   Reply With Quote
Old August 14th, 2018, 09:23   #3
KrashDH
TDI(s): 2002 Golf
There is an oil cap seal that can wear out and cause this as well. Some people have double stacked seals, some have been fine just replacing the seal with a new one. I would try that first
When I did my last TB change, since my OEM valve cover was leaking and I didn't want to bother removing the gasket that welds itself in place, I just opted for this option from ECS tuning:
It comes with all the seals and as a bonus the actual valve cover seal can be replaced with ease so you don't need to source an entire cover again. The top is now leak free for me, which is nice. It's an option for you.
KrashDH is offline   Reply With Quote
Brake fluid cap vented? AnotherPerson TDI 101 20 October 12th, 2016 12:01
Oil Filler Cap off for 300 miles -> time for an oil change vtveg Fuels & Lubricants 8 April 5th, 2012 01:13
Take oil cap off during running and I feel exhaust coming out the oil fill. rhinotalon VW MKIV-A4 TDIs (VE and PD) 10 May 27th, 2010 11:18
FS: J-cap Black anodized finish Oil Cap letterman52 Private TDI Items for Sale/Wanted 3 March 4th, 2010 07:43
WTB: Oil Fill Cap & Orange Oil Dipstick Tube 00JettaTDI Private TDI Items for Sale/Wanted 4 March 15th, 2008 20:17
Page generated in 0.12586 seconds with 11 queries
[Output: 57.75 Kb. compressed to 52.45 Kb. by saving 5.30 Kb. (9.18%)]
