Old August 11th, 2018, 07:11   #1
jbourke367
Default Inspection - Crash Sensor
So my car is due for inspection in September. In its current state it will not pass due to the airbag light on the dash. The light is for the crash sensor on the drivers side.
2 Faults Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
29-10 - Short to Ground - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
I was going to start with unplugging the battery and waiting 10-20 minutes, unplugging the sensor and inspecting the wires, cleaning the connections then plugging back in to try and clear the code. My question is how to get the carpet up. After some research it seems that this sensor is not under the seat but underneath the carpet. How exactly do I pull the carpet up? I am not sure what trim I have to remove to do so.
jbourke367 is offline   Reply With Quote
Old August 12th, 2018, 18:01   #2
joep1234
I had a crash sensor in the front under the bumper cover of my Beetle that would trip a code every time I hit a large water puddle. You could clear it once it dried out. The fix is to clean the terminals and use dielectric silicone on it when you plug everything back up.
'04 Beetle TDI w/BEW and DSG
joep1234 is offline   Reply With Quote
Old August 13th, 2018, 07:14   #3
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
I'm surprised it's be a fail - in NY it's only the check engine light that will cause a fail. ABS and airbags don't matter (or really anything besides the ECU saying it's ready)
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old August 13th, 2018, 07:21   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Remove the seat, pull the sill plate trim up and hang it out of the way (you do not have to remove it completely), and pull the carpet up enough to reach in there to get access.
I would not go through all the trouble of "inspecting" it, just get a new sensor and replace it and clear the DTCs.
oilhammer
www.cardocautomotive.com
Old August 13th, 2018, 07:37   #5
compu_85
Gadget Guy
compu_85's Avatar
Also, for 1999.5 cars anyway, there are only the side impact sensors mounted on brackets, under the sound deadening, under the carpet, under the front seats; and the sensor(s) built into the SRS module. There are no sensors on the front of the car.
To remove the carpet: Remove the seats, center console, b pillar trim, and sill trim.
I want to say the sensors are mounted are mounted just in front of the "cross bar" running across the floor of the car. They might be just in front of the seat track... I can't remember.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old August 13th, 2018, 10:53   #6
jbourke367
-J
I am having trouble finding this part online to purchase. Does this mean the entire SRS module must be replaced? I cannot seem to find the crash sensor by itself for purchase on a 99.5.
Old August 13th, 2018, 11:04   #7
oilhammer
oilhammer's Avatar
I believe there are two versions, with or without side bags, because I think those were still an option in '99, but most of our cars had them?
You can give the dealer your VIN, then have them search ETKA for G179, and it will call out (usually) which one your car needs. But there are sometimes mistakes in ETKA.
Best to get the part number off of the sensor. It takes 10 minutes. It is on the body brace that the forward mount of the seat attaches to. You do not need to take the center console out. Seat, sill plate trim, pull of the carpet, and it is right there. You can usually see the wire harness heading to it once the sill plate trim is up.
oilhammer
Old August 13th, 2018, 13:01   #8
compu_85
Gadget Guy
compu_85's Avatar
Even Mk3s with side bags had side crash sensors IIRC. Side airbags were standard for 1999 Mk4s.
Looks like the sensor is NLA now?
https://parts.vw.com/p/Volkswagen_19...J0909606M.html
It might be superseded.
Present:
Past:
Old August 13th, 2018, 13:11   #9
oilhammer
oilhammer's Avatar
6Q0-909-606-K-001 or 002 is what I come up with, the 001 or 002 has to do with it having side airbags or not.... but then when you look it up for a newer car, that I know has side bags, they still list both numbers but no description, just the PR codes.
I think the Golf CL did not have side bags, that may be why ETKA shows that. Not sure though.
oilhammer
Old August 14th, 2018, 07:57   #10
Exprod
TDI(s): golf
having the exact crash sensor. please update in what you've done to fix the problem. thanks in advance for everything! also thanks everyone else for all you posted, i feel it would come handy.
Exprod is offline   Reply With Quote
Old August 18th, 2018, 09:54   #11
jbourke367
Default What a headache
I am in the process of getting the old sensor out so I can grab a part number off of it. In the process I found that the entire floor of the car is soaking wet! No wonder the sensor is shorting out! I have water dripping out of the grommets and there is a small puddle underneath the car at one of the grommets in the rear. What do I do? Where do I start? idparts sells the grommets for underneath the car but is that likely the issue?
Old August 18th, 2018, 10:28   #12
jbourke367
All of the sensors I am finding are red in color vs. this tan one. Is that okay? Or is there something different with it?
Old August 18th, 2018, 10:43   #13
Genesis
Fuel Economy: 53/48/42
Got sunroof? If so there's a decent chance the drains (rather, the lack of draining) are the cause of it.
The other high-probability possibility is a plugged drain from the A/C evaporator pan or (you hope not!) a perforated pan itself. The former you can usually clear, the latter sucks badly as you have to pull the entire dash to get to it.
Genesis is offline   Reply With Quote
Old August 18th, 2018, 11:20   #14
jbourke367
This is the view from inside the car looking at the backseat. Are the grommets supposed to plug the hole completely? Or allow the car to drain if water gets inside? Right now its basically a straight shot to the driveway. I seem to learn everything the hard way.
Old August 18th, 2018, 11:22   #15
jbourke367
No my golf does not have a sunroof
Airbag Crash Sensor tactdi VW MKIV-A4 TDIs (VE and PD) 25 March 2nd, 2017 11:01
help with crash sensor g179 naras Other VW Group TD(I)s 0 February 2nd, 2011 11:04
Code 01221 - Crash Sensor khoutler OBD Scanners 4 March 15th, 2009 05:02
Code 01221 - Crash Sensor khoutler TDI 101 2 March 12th, 2009 12:39
Crash Sensor Replacement POWERSTROKE VW MKIV-A4 TDIs (VE and PD) 0 July 28th, 2008 04:36
Page generated in 0.16568 seconds with 11 queries
[Output: 134.03 Kb. compressed to 112.30 Kb. by saving 21.73 Kb. (16.21%)]
