Old August 1st, 2018, 12:40   #1
drexer13
TDI(s): 2004 Jetta
Default Head gasket only lasted 6000 Miles
Hello Everyone,
Im just looking for a bit of advice. My car is a 2004 Jetta with a bew. It has a Garret turbo, straight 2.5 exhaust and a cold air intake. Boost peaks at around 24 psi. The PO installed everything and had it tuned. I just (6000 miles ago) finished putting the motor back together after the cam and lifters self-destructed. I took the head to a buddy who pressure tested it, milled it flat and installed new valves guides. I reassembled the head and put the motor back together, and now 6k later the head gasket is blown.
What do you guys think might have happened?
Are there some common mistakes I might have made putting this thing back together?
Could the increase in boost pressure have anything to do with it?
Where does everyone get their parts? Is it possible that I just received a junk gasket?
Anyone else had a similar experience?
Any help with this is really appreciated.
drexer13 is offline   Reply With Quote
Old August 1st, 2018, 12:51   #2
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Did you use new head bolts and torque them correctly, and in the correct pattern?
First stage, 30 lb-ft
Second stage, 44 lb-ft
Third stage, turn 90 degrees
Fourth stage, turn 90 degrees
Was the correct thickness gasket selected based on piston protrusion?
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old August 1st, 2018, 12:52   #3
mr.loops
TDI(s): 2002 jetta
Hmm. Could be the HG at fault or possible installation error on your part
Got to ask; did you install new head bolts? Was it correctly torqued to spec?
Was the block checked for flatness?
mr.loops is online now   Reply With Quote
Old August 1st, 2018, 13:06   #4
pdq import repair
Fuel Economy: 38.5
Did the headgasket blow for sure? What are the symtoms? Where did you get the parts? Did you replace the bolts? Blow the holes before assembly?
Many many variables to conclude anything at this point.
pdq import repair is offline   Reply With Quote
Old August 1st, 2018, 13:12   #5
drexer13
TDI(s): 2004 Jetta
Thanks for the responses guys I really appreciate it.
I did use new head bolts, I used the tightening pattern in my manual and torqued them according to the instructions. The deck of the block was also well within spec as far as flatness goes, but I didn't prep it in any other way except for giving it a good cleaning. is there something else I should have done to help the gasket seal better?
Old August 1st, 2018, 13:32   #6
Mike_04GolfTDI
Other than making sure the head and block are clean and flat, and the bolts are torqued according to specifications, there's not much else to it.
If you're sure the head gasket has failed, I guess the only thing to do now is pull the head off and have a look.
Old August 1st, 2018, 13:57   #7
drexer13
TDI(s): 2004 Jetta
"Was the correct thickness gasket selected based on piston protrusion?"
No, I just matched the gasket thickness from the old gasket. Ill be sure to take that into account when I order parts for round two. Thank you
"Did the head gasket blow for sure? What are the symptoms?"
I’m sure the gasket is done. Initially I just noticed that the boost was way down, I thought it was probably a blown hose, but when I popped the hood I noticed the coolant was black instead of red, then I noticed a bit of oil seepage between the head and the block, then I had my wife sit in the car and rev it bit and found that exhaust and boost are also escaping between the block and the gasket. Miraculously it doesn’t look like there is any coolant in the oil but jury is still out on that.
"Where did you get the parts?"
I bought a cheap gasket kit with bolts off of eBay. But the head gasket itself I bought from another reputable online dealer. (I hesitate to name names because this could have very well been user error.) It came in a VW box so I assume it was oem.
Maybe the cheap bolts are to blame?
"Blow the holes before assembly?"
I ran a tap down each hole to make sure there were not any buggered threads and then I did indeed blow the holes out before assembly.
Old August 1st, 2018, 16:12   #8
There are a lot of sub standard torque to yield bolts out there. I think you found your problem. You're running 10 PSI more than stock boost. I would only use OE VW head bolts in this case.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old August 1st, 2018, 16:36   #9
flee
Fuel Economy: 40-ish
If this happened to me I would probably buy the ARP's the second time around.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old August 1st, 2018, 17:00   #10
drexer13
TDI(s): 2004 Jetta
Thats funny I was just looking for some arp head studs.
Old August 1st, 2018, 17:22   #11
flee
I assume your buddy is skilled at skimming a TDI head.
I would check it again and make sure he didn't take off so much that the valves
are now out of spec for extending past the head. It's something like 1.0 mm.
You didn't deck the block so just match the factory gasket's # of holes.
Old August 1st, 2018, 18:13   #12
No genuine ARP studs for PDs.
Old August 1st, 2018, 18:13   #13
drexer13
TDI(s): 2004 Jetta
Thanks I'll check when I pull it apart again. I didn't even check when I assembled the head the first time. My buddy has been doing head work since he was 13 and hes in his 40's now. So I usually just take his word for when he tells me its good to go.
The original gasket was a 2 hole so Ill order another one. Is the factory gasket okay for a higher boost motor or should I be looking for something else?
Old August 1st, 2018, 19:00   #14
ktmkris
Kerma has arp headstuds for the pd engine. They are pricey though
ktmkris is offline   Reply With Quote
Old August 1st, 2018, 19:04   #15
mr.loops
TDI(s): 2002 jetta
Make sure to post some pics of the pulled HG.
Blown head gasket. At 68k miles. Bendite VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 16 May 8th, 2015 09:02
ALH 280K miles head gasket advice? CyberMindGrrl VW MKIV-A4 TDIs (VE and PD) 17 April 25th, 2015 04:01
How well has your Rebuilt or Brand New AMC replacement cylinder head lasted? rbt_stack VW MKIV-A4 TDIs (VE and PD) 34 September 14th, 2014 12:06
Head Gasket changed, motor won't rotate, need thicker head gasket? slam VW MKIII-A3/B4 TDIs 94 January 11th, 2012 20:16
Head gasket leaking after only 7,150 miles *DELETED* Andy_R_Torres VW MKIV-A4 TDIs (VE and PD) 2 August 1st, 2005 12:37
Page generated in 0.15208 seconds with 11 queries
[Output: 124.14 Kb. compressed to 103.63 Kb. by saving 20.50 Kb. (16.52%)]
