Hi there,
Car- left hand drive VW PASSAT B5, 1.9diesel, year 2000.
I had problem with right side brake light/bulb. I took out the bulb holder and cleaned the brake bulb socket, all lights were working but then suddenly after couple hours I had blinking yellow 'ENGINE MANAGEMENT LIGHT' on my dashboard.
Then I connected my car with VCDS-lite and I had '00741 - Brake Pedal Monitoring 27-00 - Implausible Signal' fault. I read it's something about brake light switch etc. but in my case when I took off the cables from both rear bulb holders after fault clean the fault didn't come back.. but once I re-connected again fault was back.
I did found out that if there is no bulb (if I took out) on my rear left side bulb holder then there is not working any lights in rear side at all, isn't that strange, or it's passat thing ?
I read about Bin.Bits so Here is pictures:
*When all lights are off. http://postimg.org/image/gikd3c8t7/
*This is picture when lights are on http://postimg.org/image/eo5ofzfnv/
*This is picture when lights are on and I hold brakes. View image: 20141018 180426
Are they okay ?
What could be the problem to having that fault ?
Btw. what all 3 temperatures mean ? I know the last is the engine temperature but what other 2 ? Also what do you think Mass Air / Rev. and duty cycle are okay ?
Regards
Are they okay ?
Regards
