ss04vv
If interested, msg for pictures and/or more information
I'm in the middle of piecing back together my 03 Jetta Wagon after a lifter took out my cam and a valve (no piston to valve contact, just did some damage to the top of the lifter stem). Tons of new parts. Never planned to sell this car but just picked up a Unicorn of a TDI, 5 spd Land Rover Discovery from Spain so contemplating selling the JSW. Below are a list of information and parts I'm in the middle of replacing. Expect to have the car done in a week or two. I've been working on these cars for 10+ years, and building cars in general for another 5+ on top of that and always do everything OEM++ and by the book.
Details: ~260k, Silver, Wagon, Black leather w/sunroof, 2nd owner (for 4ish years), no accidents, very small amount of rust at fender and rear hatch (original owner spent all winters in florida - retired ex-plane mechanic so he was almost as anal with the car as I am), all service history/parts receipts since new.
List of brand new parts alone totalling just under $4000 (like I said, I never planned to sell this car) Engine parts from IDparts.com and suspension from Rockauto - All receipts available and photos of work in progress as well. Also has a set of 70% Bridgestone Blizzak winter tires on OEM alloy Rims. Will likely need new summer tires on the 2nd set of OEM Alloy rims.
ENGINE
- rebuilt head (everything new)
- Cylinder Head Install Kit (A4 ALH)
- Head Bolts: OEM
- Head Gasket: 1 Hole
- High Mileage Timing Belt Kit (ALH)
- Camshaft Sprocket: OEM
- Oil Cooler Gaskets: Yes
- Serpentine Belt: Gates "Green Stripe"
- Hard Coolant Pipe o-ring:
- Serpentine Belt Tensioner Style: Shock Only
- Coolant: None Needed
- Timing Belt: Continental
Upgraded Complete Injectors w/ Bosio Nozzles
- Core Charge:
- Prepaid Return Label:
- Nozzle Option: Bosio PP 520
- Model Year: 2003- Intercooler Bracket (ALH Jetta Golf)
- Malone Stage 1.5 Tune (not purchased or installed yet, but intended to be purchased and installed at discretion of new owner)
- 3 x Complete Filter Pack (ALH)(BEW) (all included)
- Air Filter: Mann w/Prefilter
- Cabin Filter: Charcoal
- Fuel Filter: MANN-FILTER
- Add 2nd Oil Filter:
- Cam Follower/Lifter Set (A4 ALH)
- Vane Actuator VNT-15/VNT-17 (A4 ALH)
- Actuator Circlip
- Oil Filter Flange Gasket (A4 ALH BEW)
- Oil Pan Gasket (A4)
- Oil Pump Pickup Tube O-Ring Seal (VW)
- Turbo Oil Feed Line Banjo Washers (A3)(B4)(A4)(B5.5)
- Diesel Fuel Hose 3mm (Return Line) - 1 Meter
- 5-Speed Short Shifter
Suspension/MISC
- MONROE 21715255613 Suspension Kit (2 new Quickstruts, and 2 new shocks)
- Complete Suspension Bolt Set - Struts and Shocks (A4)
- 2 x Rear Shock Mount (A4) $31.90
- Rear Towing Springs PAIR (A4 Jetta Wagon)
- CURT 11083 Trailer Hitch & wiring
- Armrest Hinge Repair Kit (A4)
- Vented Fender Liner [OEM] (A4)
- POWER STOP ESK840 4 corner Rotor & Brake Pad Kit
ENGINE
- Head Bolts: OEM
- Core Charge:
- Actuator Circlip
Suspension/MISC
