I am not sure if this has been posted previously. Apologies if it has.
I replaced my noisy dual mass flywheel in my 2006 Jetta at 66+K miles... couple of months ago
Today I cut open the main flywheel section with the floating ring in it. The floating ring is where the drive hub rivets to, the hub drives the DSG trans input shaft.
There was a large amount of grease, two spring sections with dual springs that work against the floating ring.
Below is the whole assembly minus the section cut off
below is the floating ring section
