MayorDJQ said:
If the clutch is failing, then all gears would be difficult to engage.
True to a certain extent, but always worse in 1st and reverse, because that is when the "syncro's" need work the hardest to "syncronize" the shafts/gears ect.
NuklearTDI said:
So, I shifted to second and used that to move the car a little bit, then it shifted fine.
A reasonable test, so it would seem the 2nd gear "synchro" is able to equalize the shaft speeds at a stop, but 1st gear "synchro" cannot.
NuklearTDI said:
Well, it was never happy with shifting into first when rolling to a stop, but when its getting difficult to shift into first, it doesn't matter if I'm rolling or completely stopped.
Rolling is when it should be easiest to go into 1st, (obviously at 1st gear speeds) because shafts speeds are closer to being the same.
Note that if the clutch is not releasing fully, then its VERY difficult for the syncro's to equalize shaft speeds
at a stop. Why? Because the output shaft is
stopped and the clutch is trying to force the input shaft to spin, and the poor abused "syncro" is trying to
stop the input shaft(equalize the input and output shafts) as you put it in gear.
Any "mooshy" (thats the technical term
) feel to the clutch pedal? (indicating a hydraulic problem) Take a flashlight to the hydraulics, looking for leaks, and check the level.
Does it go into 2nd, when the 1st problem happens, everytime, smooth as silk, no problems?
