Old June 6th, 2018, 04:33   #1
360gtracer
360gtracer's Avatar
Default Infotainment and backup camera issues
I just scanned all 29 pages of the common issues thread and only saw one of these addressed, and not exactly my issue, either. Car is '15 GWS, 6MT.
Infotainment - how do I get the system (non-Nav, but with large touchscreen) to display album artwork from my ipod? I saw the post about the artwork pixel size, but that shouldn't be the issue because the same ipod displayed the artwork just fine in a '17 GSW All-Trak loaner with the same infotainment system. Do not have the VW lightning plug media cable, just 30 pin but with Apple adapter for 30 pin to lightning (gen 6 ipod). In the All-Trak loaner, the ipod was plugged in via USB, but my '15 has not USB input. Thoughts, ideas?
Backup camera - our driveway is about 100' long. Backing out, about halfway, the camera blinks off for 2-3 seconds (does not close up), then comes back on and works fine after that (not that I'm backing up much longer). On the loaner? No issue, camera on for as long as it's in reverse. Thoughts/ideas on this one?
Thank you very much.
George P.
Central VA
'04 J Wagon - now owned by friend, 255K+ miles!
'15 GSW - blue/beige/6sp - 30K/yr, avg ~50mpg
'12 Passat SEL - Ti/Nav/DSG - used w/ 72K miles
360gtracer is offline   Reply With Quote
Old June 6th, 2018, 04:51   #2
740GLE
the 15's dont have the second version of the infotainment system of the 17 loaner you had, '17 has car play you do not. There is a reason the '15 version of the infotainment was quickly replaced.
While the screen may be the same the guts in the glove box are different. does the '15 still have the VW proprietary MMI connection? if so, you are SOL unless you start tossing parts at it.
If you want to start tossing parts at it, you should look into tossing the new digital dash of the '18s in instead, it's bound to be much more interesting to look at that album art work.
Old June 6th, 2018, 07:20   #3
360gtracer
360gtracer's Avatar
By "proprietary MMI", I presume you're talking about the media interface cable, yes? Yes, that's exactly what I have (cable w/ odd plug provided by VW). I thought I'd just try plugging in via the USB cable, but there is no USB port in this car.
Thanks very much for the input. Looks like SOL it is!
Still interested in anyone's thoughts of the backup camera blinking off for a couple of seconds - or is this also related to the version of the system I have?
Thanks again.
George P.
Central VA
Old June 6th, 2018, 07:35   #4
smittyatl
TDI(s): GSW
I also have a long driveway.
From personal observation, I believe the backup camera goes black when you exceed 5 MPH in reverse.
smittyatl is offline   Reply With Quote
Old June 6th, 2018, 07:38   #5
STOKTDI
Yeah when I leave my moms driveway I give the car a little bit of throttle, and the rear view camera immediately goes black. When I back out without using the throttle at all its fine.
STOKTDI is offline   Reply With Quote
Old June 6th, 2018, 09:37   #6
360gtracer
360gtracer's Avatar
Ah - I never put those two together. I'll have to check for that.
Thanks!
George P.
Central VA
Old June 7th, 2018, 05:21   #7
360gtracer
360gtracer's Avatar
Nailed it! Backed out very slowly this morning, camera never went black.
Thanks!
George P.
Central VA
Old June 7th, 2018, 06:39   #8
smittyatl
TDI(s): GSW
I actually took my car to the dealer about it and no one could reproduce it.
Best I can tell, it cannot be coded to a higher speed.
Anyone know otherwise?
Backup Camera flashpeacock TDI 101 0 December 8th, 2015 13:10
Backup camera HELP! wispassat VW Passat Family (NMS and B7) TDIs (2012+) 23 September 24th, 2015 08:09
Backup Camera issues, very dim screen Gammey Upgrades (non TDI Engine related) 6 August 6th, 2014 08:41
2013 Passat with RNS-510 Nav and Backup Camera Issues. NovaScotian VW Passat Family (NMS and B7) TDIs (2012+) 7 September 7th, 2013 22:47
Backup camera boomer sooner VW MKVI-A6 Jetta Sedan (~ 2011+) 1 July 4th, 2013 21:41
Page generated in 0.15267 seconds with 11 queries
[Output: 87.15 Kb. compressed to 75.15 Kb. by saving 12.00 Kb. (13.77%)]
