Old May 2nd, 2018, 11:23   #31
Grigg3
For my 2015 golf wagon I used Tekonsha or Towready harness #118646, which is not correct as it comes but very easy to move wires and make it work perfectly for the wagon.
Only splicing is to find power for it, I used nearby accessory outlet in trunk.
Instructions here
http://forums.tdiclub.com/showthread...02#post5347402
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
Old May 2nd, 2018, 12:27   #32
Face It
Originally Posted by Discovery View Post
Victory!
Can't wait to see more...
Face It is offline   Reply With Quote
Old May 2nd, 2018, 13:27   #33
Discovery
The good part is, you can also not see it at all!
7way plug screw and glue on the bumper. Cord is fish thru a plug inside the trunk with a dab of silicon glue to seal it off.
Discovery is online now   Reply With Quote
Old May 2nd, 2018, 13:39   #34
Discovery
Next step is to plug everything, including the brake controller.
Maybe I will be able to test everything with my camper this Friday.
Also, a short video to show where the hitch is bolted
https://youtu.be/hwX_ozd-4rg
Old May 3rd, 2018, 10:36   #35
Face It
That is slick
Old May 3rd, 2018, 11:11   #36
The Tortoise
Damn. That is great.
The Tortoise is offline   Reply With Quote
Old May 4th, 2018, 08:58   #37
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
OH WOW! I'm in! Now I just need to buy a reason to get a tow hitch.
Thanks for sharing Discovery!
Mrrogers1 is offline   Reply With Quote
Old May 4th, 2018, 09:48   #38
The Tortoise
Can anyone comment on how the GSW DSG would do towing a small boat, say something like a 16' tinny?
I am sure the towing part would be fine but I have concerns around pulling it out of the water.
Old May 4th, 2018, 11:37   #39
bitslop
I am guessing not well; from the 2015 GSW owners manual:
bitslop is offline   Reply With Quote
Old May 4th, 2018, 11:50   #40
The Tortoise
*Shrugs*
From earlier in the thread - https://www.thetowcarawards.com/tow-...lkswagen-golf/
Old May 4th, 2018, 12:12   #41
740GLE
Code the ECU for towing and that heat is nothing more than an afterthought.
They say the same thing with the Alltrack, but few people ignore it.
I'd just be aware of the total weight you're towing, a 16' skift or boston whaler may not be bad, try and not use the most steep boat launches and you should be fine, no need to slide back and end up a video on youtube.
Old May 4th, 2018, 12:50   #42
The Tortoise
Interesting about coding the ECU for towing, didn't know that's a thing.
I figure a 16' aluminum would probably be around 1200 pounds, so way lighter than a BW.
Old May 4th, 2018, 14:40   #43
Discovery
Not having a garage sucks.
Wiring part of the project have been delayed due to intensive rain.
But.
In the meantime I decided to make a safety chain ring for the swan neck.
Me and a friend, bashed a rod into a square
and welded it on
No picture of the final product, it is now hanging in the shed while the paint dry, but you get the idea.
Look like this thread became my journal, so stay tuned for more!
Old May 5th, 2018, 16:47   #44
Discovery
Wiring completed at 90%
Only problem, how do I remove the hood handle??? I need to access the BCM to steal the brake signal for my brake controller...
Edit: Praise 1854sailor!
Old May 7th, 2018, 05:38   #45
740GLE
But.
and welded it on
Knock on wood that swan neck doesn't fall out of the receiver, otherwise those "safety" chains aren't too safe. Better than nothing I guess.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
2015 TornadoRed TDI Golf Sportwagen- On the Road Groundhog Golf TDI Picture Gallery 27 June 25th, 2018 21:17
2015 Golf SportWagen TDI S novice owner Embassy_Marine TDI 101 2 March 12th, 2016 06:54
2015 golf sportwagen towing springs rage144 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 3 August 4th, 2015 16:04
New 2015 Golf TDI Sportwagen TDIPro TDI Fuel Economy 3 July 30th, 2015 17:47
2015 Golf Sportwagen TDI manual availability? johnspear23 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 26 April 18th, 2015 07:03
Page generated in 0.19924 seconds with 11 queries
[Output: 124.95 Kb. compressed to 104.11 Kb. by saving 20.83 Kb. (16.67%)]
