Old May 1st, 2018, 04:52   #61
Victor Huge
Victor Huge's Avatar
TDI(s): Mk7 Golf TDI
Checked this morning and pressure was exactly 1700hpa before start, key on raises pressure instantly from electric pump, then starter engages and this time it fired fairly quickly but died right after, starter kept going and engine started normally very shortly after. Seems like it's the valve timing solenoid...
Victor Huge is offline   Reply With Quote
Old May 1st, 2018, 04:58   #62
thundershorts
I had the long crank issue occasionally, maybe 1 out of three starts until I replaced the lift pump with the latest part # one. Now no longer hear the pump hum and no longer get the long crank issue. the part # suffix was AN I seem to remember.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old May 1st, 2018, 05:14   #63
thundershorts
I had replaced the pump because I had emitted a loud screech sound and left me dead on the highway. VW refused to pay as they found no trouble. Lift pump itself throws no codes other than low rail pressure. Why would VW change the part unless they knew that the earlier one was a problem? Besides most of these cars sat for 2 years dormant, pumps sitting in funky fuel.
Old May 1st, 2018, 07:06   #64
Victor Huge
Interesting, do you have the updated cam adjuster? What was your rail pressure before and after?
Old May 6th, 2018, 04:16   #65
thundershorts
Victor, my car was a fairly late build date, late May, so it probably has updated adjuster. I didn't bother to check rail pressure before changing lift pump as the pump had shown signs of failure by its sounds and by leaving me stranded. No further long crank issue and the pump is almost inaudible.
Old May 23rd, 2018, 13:25   #66
stu75038
You got a leaky/sticky vvt valve. Probably cause the oil on average is too dirty. Change your oil AND clean your vvt valve. Watch the below video...will save you a lot of pain and anguish.
https://www.youtube.com/watch?v=DXvHdmq0reA
stu75038 is offline   Reply With Quote
Old May 23rd, 2018, 15:28   #67
Victor Huge
I didn't know cleaning it was an option but i did see diagnose Dan's video and i think that's the issue. Unfortunately the dealer in Canada lists the old part with that big bulb on it. Any idea what that part is for guys and gals? In any case, at some point I'm going to change it
Forgot to add to thundershorts (love the name) that i don't think my fuel pump is the issue as it sounds good.
Old May 29th, 2018, 06:36   #68
stu75038
I'd assume if Dan-the-man can dissemble the old part then so can we. Soak the metal bits in a solvent and scrub-adub-dub. Just now noticed that Smertrios had already found that video 8 months ago and posted it on this thread...I'm bad about reading all the posts before posting....good find Smertrios!
Just curious for my own protection from such an issue...how often do you change your oil and filter?
Stu
Old May 29th, 2018, 07:19   #69
Chris Bell
Then make sure you read post #s: 52, 53 & 57
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old June 3rd, 2018, 20:39   #70
CruisingWagon
CruisingWagon's Avatar
My car has done this on a few occasions since I've owned it too. However, this week it became worse. It was happening on almost every start. Took it up to VW and they said it's bad fuel but cleaned my fuel injectors anyway.
Incidentally, I did buy fuel at a different station so I'm waiting for this tank to empty and fill up at my regular place.
We'll see what happens.
CruisingWagon is offline   Reply With Quote
Old June 3rd, 2018, 21:24   #71
Lightflyer1
Lightflyer1's Avatar
"Bad fuel" is a common reason given by VW for almost anything wrong with your car. Take it with a grain of salt. Unless you are really buying some rot gut fuel somewhere.
2015 Beetle TDI.
Old June 7th, 2018, 04:33   #72
thundershorts
My contention is if its bad fuel, I want them to give me a lab report, not some wanker service writer telling me so. I was told my fuel jelled, so I put a sample in my sub zero set to -14f and left it there for 24h, nothing happened except it changed from yellow to slightly cloudy yellow. They refused to change the lift pump, although it was screeching at -7f. its obvious to me vw changed the lift pump part# because of some known problem with the pump and the long crank issue many here have experienced. If you read the extended warranty at the bottom of page 5, it states that any disputed issue with the warranty, customer shall prevail. I'v asked customer service to explain that phrase and they said the legal dept would call me and two weeks have gone by with no call back from legal dept. One supposed regional manager, Sharon, told me that the wording in the warranty didn't exist.
Old June 8th, 2018, 10:26   #73
CruisingWagon
Well, I'm halfway through the next tank of fuel and it hasn't had a long crank since. The reason I go back to that service department is that they've never steered me wrong that I know of.
Plus, if I was a dishonest Service Advisor I wouldn't tell my customer: "I don't want to charge you a diagnostic fee. We think it's bad fuel but they cleaned your injectors for you anyway. Fill up somewhere else and if it's still doing it let me know and I'll have you back for a better look."
Instead I'd tell them: "Yep, looks like you're low on turn signal fluid. We filled it up for ya. Only 500 dollars. It will take about a week for the sensors to catch up and then it will start like it's brand new!"
Old August 7th, 2018, 10:39   #74
dieslin
Fuel Economy: 45
My 2011 is having this extended crank when it sits. Yesterday i didnt think it was gonna start... what have you all tried so far t narrow it down? Fuel filter?
dieslin is offline   Reply With Quote
Old August 8th, 2018, 18:55   #75
marcusku
Fuel Economy: 56/52/48
There are a lot of ideas on the cause but I don't think it has been nailed down yet. Certainly a solution has not been confirmed at this time.
15' Golf Sportwagen SEL 6 speed manual, red
02' Golf GLS 6-speed, white, sold at 308k
marcusku is offline   Reply With Quote
99 Golf long crank time to start rrraabit VW MKIV-A4 TDIs (VE and PD) 18 June 16th, 2016 21:29
Hard start .... long crank syndrome AndyBees VW MKIV-A4 TDIs (VE and PD) 7 September 10th, 2012 17:31
Long crank white smoke on start up dieselg33k VW MKIV-A4 TDIs (VE and PD) 9 May 18th, 2012 17:11
long crank time to start '04 PD tdi jetta 2004PlatinumTDiSport VW MKIV-A4 TDIs (VE and PD) 7 May 8th, 2012 19:07
long crank and white smoke after start oh-man67 VW MKIV-A4 TDIs (VE and PD) 17 January 30th, 2012 09:30
Page generated in 0.17703 seconds with 13 queries
[Output: 127.33 Kb. compressed to 105.73 Kb. by saving 21.61 Kb. (16.97%)]
