DSG TDI said:Look under Adam and Rabbit on Vortex, he shows a wheel with the paddles removed and wanted to fill the space. Chad posted the back view of the wheel also. The boss is in the wheel behind the MF switches and you will have to cut into the back of the wheel to mount the paddles. I was going to do that but found a GTI wheel with paddles and if I like it will be selling the paddles and stock leather wheel.
DSG TDI said:Got it from Underground Parts on Vortex, paid $350 for it but haven't received it yet. You can get the paddles at your local dealer or from World Impex. Look at the back view of Adam's wheel and you can see where you need to cut to install the paddles, on the stock wheel the inside edge of the switch will stick up beyond the hub but will work fine and is not that noticable. Picture courtesy of Chadcronin on Vortex
