Old January 19th, 2020, 11:18   #1
WOODWARD395
Question turbo vnt 1.9 tdi using vcds
hi been looking for the setup for installing new turbo 1.9 tdi using vcds cannot seem to find anything is there one on here if so can anyone point me in the right direction. thanks.
WOODWARD395 is offline   Reply With Quote
Old January 19th, 2020, 11:41   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
The only thing VCDS is used for is logging and adjusting boost. Otherwise it's manual replacement of physical parts
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old January 19th, 2020, 13:10   #3
Mongler98
you cant. you need to either
A: buy a tune someone has made Darkside industries or Malone Tuning
OR
B: write your own tune with a flasher and software. VCDS has nothing to do with any of this at all.
you have more searching and reading ahead of you.
my advice is to contact a tuner in your area and ask them for assistance.
as for just replacing the turbo, that's a hardware application you need tools for and parts.
Old January 24th, 2020, 09:49   #4
WOODWARD395
Red face
thanks realised how to adjust the boost now using live feed logging.
just get it as close to spec as possible that's correct is it not, thanks
have adjusted stop with mini vac 17.7hg
Old January 24th, 2020, 10:02   #5
eddieleephd
I run a log then adjust. My goal is about 150-200 mbar above peak requested.
I use the malonetuning.com website graphing feature to view the log and show the overboost.
150 mbar is 2.175 psi 200 mbar is 2.9psi. well within specs.
I have read to adjust the actuator so it starts moving at 5" and stops at 15" I think. But a proper actuator should do that and it's impossible to see when its installed by the firewall. So adjustment for boost is best I have found. However, a pain dealing with the heat of the exhaust.
Old January 28th, 2020, 09:31   #6
WOODWARD395
Thumbs up
i have burns all over my arm from exhaust plus a couple of slices out of my arm from bracket that holds sump sensor,
WTB turbo vnt-15 or vnt-17 for ALH vagpaul Private TDI Items for Sale/Wanted 1 August 17th, 2014 20:50
Turbo is dying? VNT 17 or VNT 15? Tuner Stickers VW MKIV-A4 TDIs (VE and PD) 12 March 16th, 2013 02:06
VNT-17 with a VNT-15 stamp? turbo expert eyes needed michael. TDI Power Enhancements 6 September 18th, 2010 21:02
a flange question about the vnt-15 and the vnt-17 turbo. nApkIn TDI Power Enhancements 4 December 15th, 2001 18:03
Page generated in 0.12485 seconds with 11 queries
[Output: 75.10 Kb. compressed to 65.93 Kb. by saving 9.17 Kb. (12.21%)]
