Old October 30th, 2009, 09:03   #31
Ian F
Originally Posted by Ron 33
Does anyone know how long a bearing will make noise before catastrophic failure?
Hard to say... I drove on mine making noise for at least a year... but when I first heard the noise, I thought it was CV joints... wasn't until later that I realized it was one or both of the bearings.
'03 Jetta GLS TDI Wagon, Indigo Blue, Tan leather, Monsoon, W.E. BBS RXII's. (purchased new 5/03)
'08 Dodge Caravan
('64 Mini Cooper, '72 Triumph GT6, '73 Volvo 1800ES, '79 Spitfire 1500)
Ian F is offline   Reply With Quote
Old October 30th, 2009, 09:26   #32
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Does anyone know how long it will be before I win the lottery??
If your driving consists of nothing more than driving slowly to the grocery store or to church on sundays, you can probably keep driving on it for a very long time.
If you take long drives at highway speeds, you probably want it changed sooner rather than later...
In any case, the bearing won't improve with age...
Y.
ymz is offline   Reply With Quote
Old October 31st, 2009, 16:08   #33
Ron 33
Fuel Economy: 51/44/40
You won't win the lottery. You have a much better chance of being struck by lightning.
Was wondering if anyone had experienced a complete wheel stopping failure? I did not phrase the question properly.
Changed the bearing today, all is good for another 250,000 miles.
The wear on the bearing was minimal for a quarter of a million miles.
The noise was more irratating than anything.
Thanks Scurvy.
PS
Oh yes, I used a small lockable puller to get the race off the hub. Worked great.
Did not remove the brake shield. FWIW
Y2K Jetta GLS TDI 5 Spd Atlantic Blue 346,400 miles (the only thing worn out is the paint). 700 Mile Club, 2013 Jetta GLS TDI, DSG six speed, Soon to be no more... Tornado Red. 19,652 miles. 2005 F250 6.0 Diesel 96,000 miles. Drove the F250 to Alaska summer 2015 towing an RV....what a trip!!
Newest 2017 Passat 1.8t SEL Premium, Silver, w/Gray interior.
Ron 33 is offline   Reply With Quote
Old November 3rd, 2009, 14:23   #34
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Glad it worked out for you. I keep meaning to pick up a lockable puller if I ever see one on sale. You're correct, removing the heatshield isn't strictly necessary, but removing it is quick and it's one less thing I could have bent up had I left it in place.
My front bearing lasted a whopping 100k km - don't bet on any particular life out of them!
scurvy
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old November 5th, 2009, 19:56   #35
All of Us
Ian's Dad
Default Great How-to and fantastic pictures!
Ted:
Great write up on how to change those pesky howling wheel bearings. If I ever need to do this, and I can't stop by your place to get help, I'm using this write up!
Dan
All of Us
'15 Passat SE TDI "Gin" Reflex Silver, M6
'06 Jetta TDI "Graycie" Platinum Gray, M5
'03 Jetta GLS TDI "Liath" Reflex Silver, M5
All of Us is offline   Reply With Quote
Old November 11th, 2009, 08:09   #36
CaTdi2002
Fuel Economy: 48/46/37
Default Thanks Scurvy
I did mine last weekend. No more noise ..love it. The slide hammer puller ..wow what a pain. I ended up taking the pass side off and pressing it out.
I coudnt get the bugger to move at all. It came out with the press with ease,
I think this was the bad side.
All in all great how to ... Thank god for harbor freight $80.00 bearing puller kit.
I co-worker paid 1200 for the two front bearings and labor. I offered help but
he likes to give his money away!
LOTS OF MILES 299K AND GROWING ..
My Golf is my new urban Hang glider transport
1988 SUZUKI SAMURAI 1.6TD ACME ADAPTER
CaTdi2002 is offline   Reply With Quote
Old November 11th, 2009, 15:02   #37
pruzink
Fuel Economy: 42
I need to do this on my daughter's 2001 Jetta. I have no idea which bearing (front, rear, right, left) is the culprit so I will probably change all 4 (the rear bearings look much easier to do). With her car the best way I could describe the noise is that it sounds like the car has snow tires on while the regular summer tires are on. I had the car up on jacks & everything felt tight with no obvious noise from turning the tires from hand. If you look at the pictures of the bad bearing in the begining of this thread I thought the balls looked decent but that the pitting & corrosion in the race area of the bearing was probably the primary reason for the noise.
pruzink is offline   Reply With Quote
Old November 11th, 2009, 15:38   #38
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Why bother? I would only change the one making noise. I've described how to check if a front wheel bearing is making noise - rear bearings you'll have to shake/wiggle/roll by hand and observe any notchiness or excessive play.
Also a good description. Mine usually were cyclic in making that noise - it wasn't a constant roar at lower speeds but could be at 80+ kph.
Old November 12th, 2009, 18:23   #39
MOGolf
MOGolf's Avatar
Smile MOGolf's suggestings and other pickiness
Scurvy, That's a wonderful write-up on this procedure using HF tools. However I suggest ...
... loosening the 30mm axle nut while the vehicle is still on the ground, with the parking brakes holding the car still.
... taking out the brake disc retaining screw before removing the brake caliper. You might need to have the brakes applied, or put a screwdriver through the caliper in the brake disc edge, to hold the disc while you remove that screw.
...a 27mm socket fits better than an 28mm on the welded nut of the threaded rod.
...in post #3, in the picture with the numbered parts, #3 is piece #13 in the kit (most of the pieces have numbers 955-nn where nn = 13 for this), and #5 in the picture should be turned around from what is shown. I recommend putting the thicker end against the bearing housing. #5 is the second smallest tube in the kit. #6 is the smaller of the two unnumbered plates.
... in post 4, once again use piece #13 to press the new bearing in. If I recall correctly, I was able to use #06 on the backside instead of the smaller tube plate. I was able to draw the bearings in completely in by hand. Doing by hand allows you to know when it bottoms out into the housing. No impact gun required for installing.
... when installing the hub, you say to press only on the inner race. I suggest using #13 on the backside, full width flat side against the bearing. This will support the inner race from being pushed out, and pressure of drawing the hub into place is applied to the outer race (which is pressing against the circlip in this operation). Installing a plate so that it has a portion inside the inner bearing race will prevent the hub from being fully installed.
... in post #5 "Replace the brake caliper and retaining bolts. Torque to 125Nm" It should read "Install the brake caliper and slider pins. Torque the pins to 28Nm." You'll snap off the pins at 125Nm.
Just my $0.02 worth.
Unchained motoring
MOGolf is offline   Reply With Quote
Old November 14th, 2009, 16:13   #40
dilkie
Not on a VW, but years ago I ran a Toyota's rear bearing to complete failure. It did take a long time and turning the radio volume up was my solution to try and deal with the bearing noise.
Eventually I went on a long road trip with a load in the rear of the car and the first sign of trouble was when the brakes failed on the bad bearing's side due to the high temperature burning out the brake piston seals.
A few hours later, the driveshaft was no longer turning the rear wheels (rear wheel drive) and the car slowed to a stop. The siezed bearing had worn completely through the rear axle. But surprisingly, the stub of axle that remained attached to the hub prevented the wheel from coming off.
I don't recommend it, but it's a good story now.
-lee
dilkie is offline   Reply With Quote
Old November 15th, 2009, 15:40   #41
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Thanks, MOGolf. Your suggestions have been added.
I think you may have the later version of the kit than I do, as the welded nut on mine will not fit in a 27mm socket.
Old November 16th, 2009, 16:50   #42
almus
Great write up.
I am just in the process of doing front bearing on 03 jetta wagon.
The bearing has been low growling for about 10 kmiles,
just recently it has changed from growling to howling.
I just bought a new front hub at tdi parts .com for a grand total of
only 29.95!!!
http://www.tdiparts.com/catalog/prod...roducts_id=942
Not even worth the grief of doing the dremel-bearing-race-ectomy.
By far the cheapest I had ever seen!!! I hope it is of good quality.
almus is offline   Reply With Quote
Old December 4th, 2009, 23:04   #43
MOGolf
MOGolf's Avatar
Default removing the race from the hub
I have used a puller to remove the bearing race, but sometimes it just won't grab the race.
I spent a few pennies and got the VW 3423 tool. In addtion to this tool, I used the bar and pressure screw from a Harbor Frieght bearing separater kit (like the 93980). The kit has standard thread pieces in it that don't fit the 3423. I used two formerly used engine mount bolts (N 907 124 03). Any suitably long 10mm bolts should work.
In the picture above the small disk is a 40-105 tool. It provides something for the pressure screw to press against.
Once you remove the hub, remove the bearing seal remnant from it. Position the two halves of the 3423 around the bearing race so that the inner lip will grab below the race. Secure in position with the ring. Screw in one of the screws.
Position the HF tool bar around the screw and screw in the other screw. Position the 40-105 on the hub and screw the pressure screw against it.
Using a 17mm socket and ratchet, or 17mm box wrench, or other suitable tool, turn the pressure screw while counterholding the hub. The race will come off with the greatest of ease. It took you longer to read this than it takes to remove the race.
Unchained motoring
Old December 5th, 2009, 09:33   #44
MOGolf
MOGolf's Avatar
Growler brought over a car and this time I paid attention to the pieces used.
-07 = use on the back of the bearing when pulling out the bearing and when installing the hub into the new bearing. Full flat side against the bearing during hub install.
-12 = use on the bearing when installing into the housing. This is just the right diameter to press across the face of the bearing and the outer race.
-13 = use on the bearing housing (axle shaft side) when installing the new bearing into the housing. Full flat side towards the bearing.
During the first time I tried scurvy's procedure, I found the use of HF kit washers on my HF slide hammer for removing the hub slightly bent the washers. The inside diameter of the washers is larger than the slide hammer too. Something more sturdy, and better fitting, would be required for continued use. The 5 lb. HF slide hammer (5223) has 16mm thread diameter. I took two VW M16 washers (8D0 412 145 B found on Passat front suspension), and ground down the outside diameter to 39mm. This is a mere 1mm grinding. The washers are a hefty 5mm thick. Using these two washers was better than using a single, or both, of the HF kit washers.
Unchained motoring
Old January 9th, 2010, 10:54   #45
Shenandoah
Guys,
I'm going to be doing the front wheel bearings on the 2005 Jetta wagon in a month or so.
I've got a question: Instead of unbolting the lower ball joint from the wheel bearing housing/knuckle to remove the hub and old wheel bearing, could I unbolt the axle from the half shaft and then press the axle out of the hub? That way I could pull the hub, replace the bearing, and put everything back together without affecting front end algnment. Any problems in doing the job this way? Thanks.
Eric
Seven TDIs: 2005 Jetta Wagon; 2005 New Beetle; 2004 Jetta; 2002 Golf; 2002 Jetta Wagon; 2000 Audi TT; 1999 New Beetle
Three Gas: 2000 Golf; 2002 Jetta; 2003 Jetta
Four "parts" cars: 2000 Jetta; 2000 Beetle; 2002 Golf (two of them)
Shenandoah is offline   Reply With Quote
Page generated in 0.19062 seconds with 10 queries
[Output: 133.89 Kb. compressed to 112.39 Kb. by saving 21.49 Kb. (16.05%)]
