Old January 20th, 2020, 06:39   #1
TdiRN
Fuel Economy: 42-47mpg
Default 2002 Jetta 5 speed cv axle broke free - HELP
Pulled into parking lot at work this morning and apparently several of the axle bolts snapped and now axle appears to twisted away from the transmission held on by maybe 1 or 2 bolts. There was a trail of transmission fluid to the spot I parked it. I can't see much as I am at work. I'm leaking fluid....how bad could this be??
2002 VW Jetta TDI auto->5speed conversion, Malone Stage 1
2011 F150 4x4 SuperCrew Ecoboost - 5star 93 octane/adaptive octane tunes
2017 Toyota Sienna XLE
TdiRN is online now   Reply With Quote
Old January 20th, 2020, 07:01   #2
TdiRN
Possible it took out the diff seal??
Old January 20th, 2020, 07:23   #3
oilhammer's Avatar
Fuel Economy: fantastic
Nobody can tell you until it is up on a lift and inspected.
www.cardocautomotive.com
Old January 20th, 2020, 08:07   #4
Tdijarhead
Common issue, likely whoever worked on it last didn't tighten those axle bolts properly.
Tdijarhead is online now   Reply With Quote
Old January 20th, 2020, 08:23   #5
Mongler98
If its leaking fluid there is no fixing it unless it's in a shop or garage. Hopefully it's just the seal but to replace it it not so simple as most cv axles the hub needs to come out and that's not a small task. Either way the trans might have to come out can you diy repairs or is this a toe tow to a shop for you? We have a list of trusted mechanics by state
Old January 20th, 2020, 08:57   #6
TdiRN
Well its going to be a job for a shop and I won't be able to get to it until next week.
Old January 20th, 2020, 13:06   #7
TdiRN
Just got a report from the shop....punched a small hole in the transmission. We are going to try a patch. $300.....here's to hoping.
Old January 20th, 2020, 13:28   #8
oilhammer's Avatar
Hope that wasn't the same shop that left the CV bolts loose!
Old January 20th, 2020, 13:30   #9
TdiRN
no i redid the cv axles....3 years ago? But there was threadlocker on there AND they were torqued to spec. Good times.
Old January 23rd, 2020, 13:40   #10
TdiRN
Update: the mechanic was able to patch the hole in the transmission. Filled up with new fluid and we are back on the road with a new bolt kit for the cv axle!
Old January 23rd, 2020, 14:00   #11
steve6
Make sure you keep an eye on if its leaking, if you let it get low it will burn up 5th gear
steve6 is offline   Reply With Quote
Old January 23rd, 2020, 15:59   #12
Andyinchville1
Just curious but are there any symptoms that happen prior to the 5th gear going out? .... by burn up do you literally mean smoking?
I need to check my oil too I guess ( I'm thinking one of the dangers of the plastic undercarriage tray is that it could catch a lot of oil before you know there's a problem without it if you see drips under the car as you walk to the car so you know something's up
2003 Jetta tdi wagon , 5 sp, 316k miles, 11 mm pump, DLC 520, Malone stage 1, P205 70 R 15 Ecopias on Avus rims, hammer mod
Andyinchville1 is offline   Reply With Quote
Old January 23rd, 2020, 20:40   #13
STDOUBT
STDOUBT's Avatar
And if you remove your belly pan, all kinds of crap gets flung into your engine bay, and your ferrous bits start rusting out (turbo actuator, some pulleys, A/C case etc. etc.). Keep your belly pan and side skirts ON. Much easier to simply keep an eye on your oil level through occasional use of the dipstick.
2003 Jetta TDI 1.9L 5-speed
STDOUBT is offline   Reply With Quote
Old January 30th, 2020, 07:15   #14
Andyinchville1
Hi
I agree with the idea of keeping the belly pan on ......it does seem to keep the engine compartment a lot cleaner than any of my other vehicles because they have no belly pan... on the other hand I think since my Jetta is the only one that does not leak oil probably has a lot to do with engine cleanliness also.
The engine oil isn't bad to check on occasion because of the dipstick it's the transmission I wish it was easier to check for oil levels on ( no dipstick).
Not that my car currently leaks but I'm just paranoid if it starts leaking at some point unexpectedly the belly pan would catch so much fluid that I could be damaging something without knowing it ....
Maybe a good compromise would be to drill a hole at the lowest point of the belly pan that way it would least drip fluid if things started leaking yet be small enough not to let alot of debris into the engine compartment?
Something I never thought to do was to look inside the engine compartment after driving in the rain to see if the belly pan fills with water and how water actually escapes.... I don't recall seeing a factory hole in the belly pan to let water drip out ....
5 spd mk4 CV axle replacement 1 bolt broke (pic) Suggestions BBB129 VW MKIV-A4 TDIs (VE and PD) 13 January 16th, 2019 12:20
GOLF/JETTA CV AXLE question emscar VW MKIV-A4 TDIs (VE and PD) 1 December 12th, 2015 15:10
02 Jetta CV Axle End daemon.key TDI 101 1 October 6th, 2009 10:24
02 Jetta CV Axle End daemon.key TDI 101 0 October 4th, 2009 17:56
CV and drivers side axle broke suddenly, stranded...help DOCTOR SHUMES VW MKIV-A4 TDIs (VE and PD) 6 May 4th, 2006 23:42
Page generated in 0.18702 seconds with 13 queries
[Output: 119.16 Kb. compressed to 99.43 Kb. by saving 19.73 Kb. (16.56%)]
