tdibeliever
My search skills aren't that great so fogive me if this has been answered elsewhere in a different form.
I recently aquired a 99.5 Jetta. It's a reasonably solid car that needs some love. Most note-worthy is the engine is coming out for a rebuild. Low compression, a nasty RPM dependent vibration (bent rods I think), probably a failing DMF, and it's filthy. I saved the wiring from an '01 TDI front clip I bought some years ago. I've been bitten by the Go-fast bug so I know I'll be tweaking this one too. Right now I'm looking at an 11mm pump (on hand already), PP520s (on hand already),RC tuning, possibly a larger turbo (if needed), SMF and VR6 or larger clutch package, bigger downpipe and exhaust (I'm leaning towards 2.5"- have a new cat already), at some point a PD manifold and an FMIC. For a ballpark I think 250-300ft/lbs would make me smile. My current GTD is less than that (I think) and I giggle like a little school girl when I lay into it. Given the extra weight of an A4 I think that area should make me squeal just as loudly.
I'm no stranger to swaps/frankenwagens. I've built 2L 16V vanagons, Vanarus, An A2 TDI, and currently drive a souped up A3 GTDI. Bentleys, soldering irons, and heatshrink are my friends.
That all being said, is there any real benefit to upgrading to the later model ECU? If it won't provide me with additional power/useful flexibilty I wont bother. Thanks for your time.
-Jake
-Jake
