Old July 15th, 2017, 00:41   #1
Drivbiwire
Zehntes Jahr der Veteran
Default Asphaltene Issues related to ULSD
Start using Power Service "Diesel Kleen" on every tank... Stock or Aftermarket, your injectors and fuel system will thank you!
https://www.cumminsfiltration.com/si...ne%20Boost.pdf
Must read:
https://www.sbmar.com/Maintenance/PDF/ULSD-Fuel.pdf
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old July 15th, 2017, 06:56   #2
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Get ready for all the NAY Sayers coming out of the woodwork now !!!
I've been using PowerService "Silver" only since 2005. But I do not spend winters in the cold !
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Old July 15th, 2017, 07:08   #3
Drivbiwire
Old July 15th, 2017, 07:10   #4
ZippyNH
On Heavy duty trucks where the fuel gets hot...it builds up...forms little black balls, reside..but FUEL doesn't seem to get as hot...not as much getting sent back to the tank in a TDI.
I use PS for other reasons.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
ZippyNH is offline   Reply With Quote
Old July 15th, 2017, 07:18   #5
Drivbiwire
For every unit of fuel burned 200 parts are circulated back to the tank...
The TDI circulates at idle approx 2 liters per minute of fuel, at 5100 rpm, return rates to the tank are approx 8 liters per minute.
Fuel in at the ALH TDI, has very little return rate from the injectors, these are effectively a total loss system in the sense that once the fuel is pushed to the injector nearly all that fuel is delivered to the cylinder. The problem with this is that the fuel is heated and after the 6-8 injection events required to push the fuel from the plunger to the nozzle, it has increased in temperature significantly and is easily exceeding 300-400F. This causes varnishes to form if fuel additives are not being utilized.
Old July 15th, 2017, 13:27   #6
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
I run it in every single tank of fuel. Silver bottle in the summer, white bottle in the winter.
I always figured, even if it was only for placebo effect, I was OK with it.
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old July 16th, 2017, 13:30   #7
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
I just got back in a TDI, my fourth, in May when the opportunity to purchase a new old stock EPA re-release GSW for $8K off at 0% for 72 months (a veritable no-brainer) presented itself.
I decided to experiment on the first several tanks, rotating through Stanadyne Lubricity, Stanadyne Performance, OptiLube XPD, and Power Service summer (silver bottle). The first three are all demulsifiers while PS is more preferable as the only emulsifier and will pass any water safely through the system without collecting. I'm also finding that PS is returning significantly better mpg for me, so the experimenting phase is over and it'll be PS silver until late fall, and then PS white until spring.
And a Mk7 GTI that's faster, but more thirsty.
Blue_Hen_TDI is offline   Reply With Quote
Old July 16th, 2017, 14:53   #8
tomo366
TDI Lifer
tomo366's Avatar
Optilube XPD for many years now.....
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old July 17th, 2017, 00:20   #9
lovemybug
Been using both white and grey bottle PS for many years. Started using Howe's recently, and it seems my performance has gotten better. No concrete evidence, just seat of the pants feel.
Just out of curiosity, DBW, what's your opinion of Howe's vs. Power Service?
2002 Red New Beetle TDI, Manual swap.
Mods so far: Coolant migration mod, Ventectomy, Euro headlight switch, HID retrofit, KII VCDS cable
I can't believe how much crap I can fit in this thing.
lovemybug is offline   Reply With Quote
Old July 17th, 2017, 01:57   #10
Blue_Hen_TDI
I've seen him get asked that numerous times in other threads without a response.
Old July 18th, 2017, 13:54   #11
Drivbiwire
I prefer the Power Service mostly for water control, but also for detergency and cetane increase.
Old July 21st, 2017, 16:44   #12
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
THIS. ^^^^^^^^^^^^^^^^^^^^^^^
PowerService is not an emulsifier, IIRC. It is a solubilizer according to PS.
I've been using Howes Lubricator Diesel Treat for many years with good results. Howes is a demulsifier like Stanadyne. I have transitioned to PS Diesel Fuel Supplement (white bottle) for water control and lubricity. My BMWs don't have a water separator that I can drain and have to rely on the few PPMs of dissolved water staying dissolved to pass through the system harmlessly. I'm also very careful to fuel up ONLY at busy high turnover stations along major routes to avoid getting watery fuel. I go where the big rigs go to fuel up in my area.
Note that PS Diesel Kleen (silver bottle) doesn't do anything for water and has no anti-gel for winter use in case the fuel isn't winterized. While anti-gel is not needed during summer months, I use PS Diesel Fuel Supplement (white bottle) year round to control water by keeping it dissolved and to increase lubricity. Providing some Cetane boost is another benefit. I recommend using PS Diesel Fuel Supplement (white bottle) year round. PS DK (silver bottle) is a summer only formula.
My priorities for fuel additives are to control water and increase lubricity. Providing anti-gel for winter use and increasing Cetane levels are of secondary importance.
Diesel ON!
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old July 21st, 2017, 16:56   #13
n1das
n1das's Avatar
Smile
I noticed that too with my TDIs years ago. An overdose of Howes simply shows no further improvement, if any. From my experience, an overdose of PS can result in a slight drop in MPGs. I can't tell any difference in my BMWs with Howes vs. PS in terms of MPGs and performance.
I've transitioned to PS Diesel Fuel Supplement (white bottle) for water control and lubricity. I like both Howes and PS but how PS controls water was what tipped me toward PS and away from Howes.
Member SSBMWO
Old July 24th, 2017, 13:11   #14
The Tortoise
Dumb questions. I read the owners manual and there was no mention of additives.
1) What's VW's take on additives? If something goes wrong with the DPF and they determine additives were to blame, where does that leave the owner.
2) How much benefit do they really provide? Am I naive in thinking the cars have been designed to safely burn ULSD?
Thanks.
The Tortoise is offline   Reply With Quote
Old July 24th, 2017, 15:08   #15
Lightflyer1
Lightflyer1's Avatar
VW does not recommend any particular additive. They do sell Stanadyne though. Any name brand additive will work fine if the instructions for dosing are followed.
There are those who use them regularly and those who never use them and a few in between.
First you need to determine what you are trying to fix/modify for. Those in cold climates are the usual ones to use them the most to stop/deter freezing of the fuel. Others want them for lubricity purposes and some who want the cetane boost or anti water properties.
There are many threads here on additives. I would suggest reading some and in the end you will have to make up your own mind. They stink real bad so don't spill any or get any on yourself/clothing/car/equipment. Best not to store them in the car either if you can help it as most will leak and get all over everything around. A little goes a long way in the smell department and it doesn't wash out easy either. Good luck with your decision!
2015 Beetle TDI.
Are these issues related? fruitcakesa TDI 101 20 December 24th, 2016 17:45
Several electrical issues, may or may not be related. Sbeghan VW MKIV-A4 TDIs (VE and PD) 22 February 6th, 2016 18:15
Are these electrical issues related? nicole'sjetta VW MKIV-A4 TDIs (VE and PD) 2 January 3rd, 2012 13:32
Asphaltene in Diesel Fuel Geomorph Fuels & Lubricants 22 March 5th, 2010 20:11
Four issues in a week - related? Blue_Hen_TDI TDI 101 2 May 15th, 2007 14:09
Page generated in 0.17335 seconds with 11 queries
[Output: 137.90 Kb. compressed to 115.87 Kb. by saving 22.03 Kb. (15.97%)]
