Old July 13th, 2017, 15:23   #1
03jettatdired
TDI(s): 03 jetta
Default Kerosene to clean egr and intake
I just completed cleaning the egr and intake on my 03 Jetta TDI 1.9 after 150,000 miles. Now I am looking for a way to keep it clean or at least keep it cleaner. One suggestion I've gotten is to mix kerosene with the fuel. I would like to see if anyone has tried this or if there are any other suggestions. A response will be greatly appreciated.
Thank you in advance,
Harold Walsh
03jettatdired is offline   Reply With Quote
Old July 13th, 2017, 15:38   #2
MichaelB
Fuel Economy: very good
Harold Walsh
Your engine was run on a higher sulfer spec fuel than we have now. Kerosene or as we say #1 diesel is no cleaner burning than #2. It also has fewer BTU's per gallon and your MPG will suffer and it costs more. There is nothing you can dump in your fuel tank to keep your egr clean.
MichaelB is offline   Reply With Quote
Just did intake/EGR clean out: now have new sound Fauvay TDI 101 2 March 14th, 2012 06:46
Do I have to clean the intake if I have removed the EGR? nic_a_bod VW MKV-A5 Golf/Jettas 1 November 15th, 2009 10:23
If EGR is Clean is the Intake also clean? fugazi48 TDI 101 6 August 14th, 2008 09:56
is it possible to clean my EGR/intake? danrock VW MKIV-A4 TDIs (VE and PD) 9 August 21st, 2005 02:54
EGR mod to keep intake clean !!!! rodney02 VW MKIV-A4 TDIs (VE and PD) 15 March 10th, 2003 13:30
Page generated in 0.07958 seconds with 11 queries
[Output: 52.86 Kb. compressed to 48.92 Kb. by saving 3.94 Kb. (7.45%)]
