Old July 11th, 2017, 13:08   #1
sloinker
sloinker's Avatar
Default Group V esther base synthetic oil.
I have been doing some research and it seems that Redline is the only manufacturer of a group V synthetic in 5W-30 with a 504.00-507.00 classification. Are there any other manufacturers that use a group V base other than Redline for retail users? I can't find any. Amsoil and Some Mobil 1's are group lV's with esther additives and most the rest are hydrocracked group lll's with additives. I am going to use the Redline on my 15 TDI's I just bought unless someone has a reason not to.
https://www.redlineoil.com/product.aspx?pid=142&pcid=21
https://www.redlineoil.com/content/f...PDS%205-13.pdf
sloinker is offline   Reply With Quote
Old July 11th, 2017, 14:49   #2
Lightflyer1
Lightflyer1's Avatar
It says recommended for and suitable not that it actually has the rating.
2015 Beetle TDI.
Old July 11th, 2017, 18:32   #3
sloinker
sloinker's Avatar
You're right. Sneaky. I emailed them and asked about specific VW approval.
Old July 11th, 2017, 18:44   #4
MichaelB
Fuel Economy: very good
Why do you think Redline Group V Ester based oils will perform better in your new car than PAO's or group III hydrocracked oil?
Do you have any documentation that says anything to the effect that VW approved 507.00 oils have lead to premature engine wear or failure and that a Group V ester is the cat's ass for engine wear and longevity? Just Redline propaganda? I'm sure it will perform well but is it better? Red colored boutique oil.
MichaelB is online now   Reply With Quote
Old July 11th, 2017, 22:17   #5
sloinker
sloinker's Avatar
I have been in and around racing all my life. Every engine builder I know uses either Redline, Penn or Mobil 1 after break in. I have read about the properties of Esters versus PAO's and they intrigue me. Why should you care if I'm willing to spend 50% more for oil?
Old July 12th, 2017, 02:19   #6
VwPassion
Excellent C3 oil and perfect noack but the price in my country is .... ugh !
http://www.trade-wind.gr/car/lubrica...4-pcid-21.html
VwPassion is offline   Reply With Quote
Old July 12th, 2017, 04:03   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Man what will we do here with no more new diesels being sold and thus no more new spec changes in oil? LOL. Good thing we have an almost endless appetite for oil discussions.
oilhammer
www.cardocautomotive.com
Old July 12th, 2017, 12:09   #8
sloinker
sloinker's Avatar
I heard back from Red Line. Recommended but not approved. Think I will stick with the factory fill or possibly the M1. I may try the Red Line 5W-20 in the wife's Dodge minivan that has used the MS-6395 spec dino oil since new. See if I see/feel any changes and move the drain interval to when the computer on the van says to change it. I have been doing it every 5k and the reminder hasn't come on once. 5K IMO is long enough on a group ll oil for me.
Didn't mean to start a pissing match. Just wanted some feedback Red Line oils performance in a passenger car in the real world.
Old July 12th, 2017, 12:38   #9
Lightflyer1
Oil topics generally lead to lots of discussion. There are many here already.
2015 Beetle TDI.
Old July 12th, 2017, 13:06   #10
MichaelB
Originally Posted by sloinker View Post
I may try the Red Line 5W-20 in the wife's Dodge minivan that has used the MS-6395 spec dino oil since new. See if I see/feel any changes and move the drain interval to when the computer on the van says to change it.world.
Forgive me for my input but I don't think you will"see/feel" anything and there are far less expensive high quality oils to extend your OCI. M1 for example.
Old July 12th, 2017, 14:40   #11
New Mickey
The user formerly known as mickey
TDI(s): 2015 Passat
Not sure what base stocks Amsoil uses in their European Car Forumla, but I do know that it is specifically APPROVED BY VOLKSWAGEN for applications requiring 507.00.
-mickey
New Mickey is offline   Reply With Quote
Old July 12th, 2017, 14:47   #12
New Mickey
TDI(s): 2015 Passat
ALL motor oils, regardless of manufacturer, will list a few "approvals" and a lot of "meets or exceeds the requirements of." That is standard. Nobody goes to every car manufacturer and gets "approval" for ever application.
However, no manufacturer requires oils that have their "approval." The oil only has to meet their requirements. The law (in the U.S.) backs that up.
I think it's idiotic to argue about "approval" vs. "we say so", but the performance of base stocks is another matter.
Does VW 507.00 require Group V base stocks? Not to my knowledge. Your owner's manual says "synthetic", and that's a very nebulous term.
Bottom line: If it says 507.00 "approved" or "meets the requirements of 507.00" it's the right choice. Stop worrying about how many angels can dance on the head of a pin. NO OIL MANUFACTURER IS GOING TO LIE TO YOU. They have no reason to do so, and the potential downside is enormous.
In the case of 507.00 we're talking about protecting emissions related equipment....in VOLKSWAGEN DIESELS, no less. Can you imagine any oil manufacturer daring to lie about THAT standard? In this political climate? It's not surprising at all that Amsoil sought, and obtained, specific VW APPROVAL for an oil to use in Common Rail TDIs. Nobody, but NOBODY is going risk getting pulled into that swamp. They're going to cover their a$$es and put the ball in VW's court.
If it says 507.00 it's good. Absolutely.
-mickey
Old July 12th, 2017, 15:24   #13
Lightflyer1
Read post number 8. He contacted the company and they said it is not approved for 507. Everyone can make their own choices but VW wants you to use an approved 507 oil. Very little to nothing to be gained from using this oil over a real 507 approved oil at $8 vs $13.
2015 Beetle TDI.
Old July 12th, 2017, 15:32   #14
New Mickey
TDI(s): 2015 Passat
If it meets the requirements of 507.00 then it's fine. In the U.S. at least. The Magnusson-Moss Warranty Act says so. If VW were to require VW oil then VW would have to provide it free of charge for the life of the warranty.
VW does NOT require "approved" oil. They "recommend" it. Obviously. Why wouldn't they?
Use Amsoil if you're worried about it, but Redline is just fine and dandy. Won't affect your warranty and won't harm your emissions equipment.
Of course, if you de-smog your CR TDI then 507.00 no longer applies. The stuff it's supposed to protect is no longer there. Right? 507.00 doesn't have more "stuff" in it. It has LESS "stuff" added, in order to protect the emissions equipment. So what does that "stuff" do? Is it actually lesser oil, in terms of protecting your engine? I don't know, but it's worth asking. So if you have gotten rid of the offending smog bits is 507.00 really the best choice?
I just mention that so I can eat popcorn and watch the argument. I'm going to use European Car Formula as long I own the car, even if the smoggy bits do happen to fall out somewhere for some mysterious reason......
-mickey
Old July 12th, 2017, 22:05   #15
VwPassion
Meet : Just covers exactly the min. req. ... Nothing more . 5 out of 10 , literally base grade .
Exceed: Passes the test but we not know how easy . 6+ out of 10 .
How much + , unknown .
Recommended : This is what manufacturers offer . Easy choice and properly pass the tests .7+ out of 10 . How much + , unknown .
Approved :The sneaky one . Approved can be the 5/10 or the 10/10 . Our choice what we ll use if not going by the book .
http://forums.tdiclub.com/showthread...37#post5296837
(#33 post) For persons that worry too much .
I have tdi with dpf and NOT using 507 . 505/505.01 is way better for protect engine so the 30s oils are outta question for me. 40s all the way up...
Esso XD-3 PAO base stock synthetic northstar Fuels & Lubricants 1 April 18th, 2003 04:43
Group III base synthetics BrightSun Fuels & Lubricants 13 December 17th, 2002 00:53
Group III oils are Synthetic??? troy_heagy Fuels & Lubricants 16 September 21st, 2001 00:57
Alkylated naphthalene - its not a synthetic base oil Dominique Cormann Fuels & Lubricants 9 May 2nd, 2000 03:30
Listing Oils by Base Stock instead of "synthetic" GeWilli Fuels & Lubricants 8 February 12th, 2000 14:26
Page generated in 0.15671 seconds with 11 queries
[Output: 130.55 Kb. compressed to 108.59 Kb. by saving 21.96 Kb. (16.82%)]
