Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 9th, 2017, 21:57   #1
vw_lover
vw_lover's Avatar
Fuel Economy: 5.0L/100km
Default 2012 Jetta TDi stick - First gear won't get in gear
Hello fellow VW,
This weekend was a blend of emotions, with the selling of my beloved 2010 GTi Coupe, and the buying of a 2012 6-speed Jetta TDi. The issue I'm having (and I took a chance when buying this vehicle) is that when stopped (or when rolling) the first gear is at times impossible to engage. It just won't. But sometimes it will just fine.
What I tried:
- release clutch, depress clutch try again: no result
- double-clutching: no result
- engage 2nd gear then first: no result
What I did notice is that when I prepare to shift in 1 gear, pushing the stick to the left, if I wiggle it forward and backward a few times, it will go in gear almost every time.
I do not think it's the tranny, which is working just fine otherwise. I took the stick boot off and there is railing that goes from the stick to the gearbox that I suspect can be adjusted (there is a little hole that allows for a pin to be inserted to align the stick in a "home" position). I check the forums and couldn't find a how-to.
I'm also planning on doing a transmission flush and look for metallic debris that might describe a synchro issue (I hope not).
Any suggestions or thought would be appreciated!...
Thanks,
Mathias
Matt / Toronto (from France... we love diesels!)
D: Golf I D 1979 / BX Ourane TD 1991 / Fiat Uno TD 1990 / 2002 Jetta TDi
G: Fiat Uno 1.1L / Golf I 1 1979 / Golf I 1.1 Formel E 1983 / Super5 GT Turbo II 1989
vw_lover is offline   Reply With Quote
Old July 10th, 2017, 05:32   #2
turbobrick240
turbobrick240's Avatar
There is a little plastic piece on the shift linkage arm under the battery that may have popped off. It happened to my golf, making first gear engagement very notchy. I replaced the plastic junk with the dieselgeek sigma six short shifter kit. Shifts way better than it ever did now.
Old July 10th, 2017, 07:20   #3
vw_lover
vw_lover's Avatar
Thanks Mate. This is my wife's car so I don't think the short shifter kit will fly with her (she don't really give a crap about this stuff). I will try to locate the plastic piece you're referring to and let you know.
Old July 10th, 2017, 09:00   #4
speed185187
speed185187's Avatar
TDI(s): 03 Jetta GL
Try adjusting the linkage
03 Jetta GL TDI reflex silver (rear ended again) OOS
2018 Subaru Outback Limited (replacement for ^^)
16 Silverado 3500 CCLB dually LML
14 BMW K1600GTL-E
speed185187 is offline   Reply With Quote
Old July 10th, 2017, 10:03   #5
turbobrick240
Yup, could just be out of adjustment too. The piece that popped off mine is a little white rectangular bit about the size of a thumbnail. It pops onto a spherical knob. Dieselgeek sells an improved version called a super slider for $25. The knob it pops onto was so worn on my golf that I elected to get the short shifter.
Old July 11th, 2017, 11:17   #6
740GLE
One thing I noticed when i drove the 6MT was the springs of the shifter gate were rather strong and took way more effort that I was expecting to get all the way over to first. Maybe if your able to get it in second you shouldn't have any problem.
How many miles on the ride?
Old July 12th, 2017, 16:00   #7
vw_lover
vw_lover's Avatar
Thanks Turbobrick240, I've seen this kit online. Will take a look at this specifically over the weekend.
740GLE: 157,000 Km so far. She's a young girl.
Gear shift won't go in 5th gear Puritan2003 VW MKIV-A4 TDIs (VE and PD) 10 April 13th, 2016 10:14
my jetta tdi won't move in gear 11TDIJET TDI 101 8 November 20th, 2014 06:01
2000 jetta tdi won't move when in gear Dan_cross TDI 101 10 March 10th, 2014 08:03
Cruise Control Fix for 2004-2006 Golf/Jetta PD TDI with upgraded 5th gear or 6th gear Mark@MaloneTuning TDI Power Enhancements 14 February 28th, 2014 18:02
Gear stick gaiter dinger Golf TDI Picture Gallery 4 May 7th, 2007 23:34
Page generated in 0.11206 seconds with 11 queries
[Output: 81.57 Kb. compressed to 70.75 Kb. by saving 10.82 Kb. (13.27%)]
