Old July 8th, 2017, 18:52   #1
FXDL
Fuel Economy: 4.4 per 100KM's
Default Liqui-Moly 4200 5W30
Is the Liqui-Moly a true synthetic.? What group is it? Seems no one knows or is there someone who does?
FXDL is offline   Reply With Quote
Old July 8th, 2017, 18:55   #2
turbobrick240
turbobrick240's Avatar
It's a good oil. Probably some group III in there, but that doesn't really matter for our purposes.
turbobrick240 is online now   Reply With Quote
Old July 9th, 2017, 02:08   #3
VwPassion
According to this , is not a full synthetic , at least as i do understand it .
Open at
safety data sheets & product information
and go to
product information
and you'll see the specs . Only bad as i see is the TBN which is only 6,5 . Low TBN for my taste ....
Edit : "...The combination of unconventional
base oils using HC synthetic technology, together with
the latest additives, ..."
VwPassion is offline   Reply With Quote
Old July 9th, 2017, 04:37   #4
I used to obsess over finding oils that were full synthetic, but since the 505.01 spec they seem to be less common, not more. I wonder if any 507.00 oils have all synthetic base stock.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old July 9th, 2017, 05:51   #5
VwPassion
..... I wonder if any 507.00 oils have all synthetic base stock.
Nope ,i didn't find any 507 spec that is pure synthetic so long but can't say for sure that is not exist .My opinion is stay away from any 507+ spec ,i not use it at my car even is a '13 tdi with DPF and i am very happy with that . Newer specs are only for fuel consumption because are thinner and obviously this help . BUT this is not help engine health . At my case i prefer change a DPF earlier , at 200k km for ex. than having engine issues . A DPF costs like 1-2k for me , and engine costs double+ money w/o count the oil "normal" consumption due to thinner oils . No thanks, i "don't buy " it...
Old July 9th, 2017, 07:02   #6
turbobrick240
There are more productive things to do with one's time than obsess over motor oil. Any of the 507 oils are perfectly satisfactory . The worlds highest mileage car (volvo p1800) hasn't seen a drop of "pure synthetic" afaik, and is still motoring along.
Old July 9th, 2017, 09:54   #7
VwPassion
http://nypost.com/2016/02/28/this-gu...-slowing-down/
Over 3M miles that volvo .....
"..Owner: Will you start as usual one more time?..No drama?
..Volvo: Wanna bet..?
..Owner:...."
Anyways,i noticed that even the oils are much better w/o doubt now-days than back then when volvo is produced ,he still change oils at 3.5k miles no matter what...
Old July 10th, 2017, 19:03   #8
Rico567
Originally Posted by VwPassion View Post
<snip>
He says he follows the manual, and on a 1966 car, the manual probably said that. My 1967 Opel Kadett said 3K, and that's what I did. This says nothing about the quality of engine manufacture and lubricants 50 years later. The manual for our 2013 Passat TDI says 10K changes and that's what I do. And UOAs (Used Oil Analysis, the only objective measure of what the oil is doing in a car), both in this forum and on BITOG (Bob Is the Oil Guy) say that the oil is still doing its job after that many miles.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old July 10th, 2017, 20:00   #9
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
..Owner:...."
I've worked on two Volvos (semi) owned by two brothers which have 3.7 and 3.5 million on the units. Neither one has had any internal work.they had 3 turbos , 2 injectors and other wearable parts.
Every single service was with the manufacturer recommended oil. No additives or hocus pocus oil. Changed like clockwork.they are probably in 4-4.5 million range now,since I don't work at Volvo anymore i dont know. My work buddy says they still come in. 50k between oil changes on syntheic blend Delco 400. 2015 onwards models got 10w30. Why? Engine liner bores machined differently and allowed decreased piston to wall clearance creating tighter seal. No need for thick oil.ive seen 2 in the 2 million range already.they only stop truck for fuel and service
Would I use this good oil in my tdi? No.
Use the oil intended for the engine. Recommendation is there for a reason.
Dannyboy is offline   Reply With Quote
Old July 11th, 2017, 00:42   #10
VwPassion
Indeed, recommendations are for a reason and for sure manual knows what it says ,but this is valid only when oils are similar quality (then-oil and now-oil) . The package of oil back then have nothing to do with the "same" oil today .That s the reason that oils back then can t compete at mileage the today oils .Never saw an '60s car to keep at its youth 20k miles oil because the oil itself couldn't last that much at '60s .
That means two things in my mind :
A) He not know what is doing by changing at 3.5k an oil that can last 10k miles (not even close the package of additives in the oil that manufacturer recommend back then when car was made versus the oil today ).
B) He knows exactly what is he doing ...
I agree for there is no need for hocus pocus oils in a car . Maybe (a careful "maybe") occasionally need to clean motor from inside but not at every oil change of course .
Old July 14th, 2017, 22:18   #11
MichaelB
I have been using this oil. The manufacturer claims full sythetic made in Germany
http://www.ravenol.de/en/products/us...sae-5w-30.html
MichaelB is online now   Reply With Quote
Old July 14th, 2017, 22:24   #12
20IndigoBlue02
20IndigoBlue02's Avatar
Open at
and go to
product information
TBN of only 6.5 is typical of 504/507 oils. It will be difficult to find, if they even make it, a 504/507 oil that has the TBN of a 502/505 oil
2016 Tiguan SE 4Motion
20IndigoBlue02 is online now   Reply With Quote
Old July 15th, 2017, 00:25   #13
VwPassion
According to that site it have mineral oils in ...
https://elit-oil.io.ua/s944902/dokumentaciya_-_msds
Just scroll little down and you ll see the msds as pdf . Go to section 3.2 Mixtures .....
" The base oil/mineral oil has a value of less than 3% DMSO .. etc etc " .Not full synthetic base oil as it claims as i see .
Old July 15th, 2017, 00:29   #14
VwPassion
That's why i am against 507 spec ,is not helping engine and i am (among others too.. ) live example that dpf is not destroyed with use of a non-507 oil....
Liqui Moly Top Tech 4200 FXDL Fuels & Lubricants 6 November 26th, 2014 15:02
Trying liqui-moly top tec 4200 Softrockrenegade Fuels & Lubricants 7 June 18th, 2014 07:23
Liqui Moly Longtime High Tec 5w30 ....... TSP-MIAMI-TORONTO Fuels & Lubricants 0 February 18th, 2014 06:53
Liqui Moly 5-30 4200 Longlife III Skatch_TDI VW MKVI-A6 Jetta Sedan (~ 2011+) 6 August 5th, 2013 08:08
Liqui-Moly Top Tec 4200 amstel78 Fuels & Lubricants 4 February 4th, 2012 09:58
Page generated in 0.15178 seconds with 11 queries
[Output: 122.61 Kb. compressed to 102.92 Kb. by saving 19.68 Kb. (16.05%)]
