Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 4th, 2017, 09:20   #1
sapper043
Default Rawtek delete with Malone Tuning. AdBlue removal?
I am in the process of completing the install for the kit. The kit and instructions are good but I would like to completely purge the AdBlue system from the car and not tie it up under the hood. I had to stop as I am waiting on the 10mm/12mm triple square drive to complete removal of the passenger side axle.
DEF left exposed to air for long periods will crystallize and harden like a rock, any why I want to remove the system completely or at least purge it and flush the system.
It appears that the AdBlue injector is liquid cooled/heater and those lines could be just looped together.
Has anyone completely removed the AdBlue system?
sapper043 is offline   Reply With Quote
Old July 7th, 2017, 13:43   #2
sapper043
Well this is proving to be a bit more work that I thought but it is coming along.
VE really never wanted the DPF and everything to come out or ever be serviced.
Old July 7th, 2017, 19:49   #3
Owain@malonetuning
What part of the word filter would make you think it would ever have to be replaced or serviced
Best of luck! there's a guide here http://www.myturbodiesel.com/wiki/dp...r-removal-diy/
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old July 10th, 2017, 16:52   #4
sapper043
Got it all apart and Race Pipe in. I wasn't thinking I should have emailed you the stock ECU file a week ago instead of yesterday.
Just waiting on that back to complete the tuning and testing.
Old July 21st, 2017, 11:05   #5
sapper043
Well now that the car is back together it has been a dream to drive now. It is so much more responsive. Both power and mileage is up as well. Anyone considering this should stop considering and do it.
I also can't speak highly enough for the people at Malone and Rawtek as they both were very helpful at various stages of the process.
Old September 4th, 2017, 19:29   #6
Tankbuster
What does this cost to do?
Tankbuster is offline   Reply With Quote
Malone / Rawtek Paulinski TDI Power Enhancements 6 January 26th, 2016 06:50
MKVI TDI + Malone Stage II + Full Rawtek w/ DPF delete CoopDiesel TDI Cars for Sale/Wanted 3 October 23rd, 2015 10:29
Rawtek Jetta TDI (11-13) DPF & EGR Delete Performance Exhaust Kit and Malone ECM Upgr JustinJ TDI Power Enhancements 32 September 7th, 2015 07:02
Another successful Rawtek and Malone install lou95gts VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 November 16th, 2013 06:22
Page generated in 0.14138 seconds with 11 queries
[Output: 71.05 Kb. compressed to 62.21 Kb. by saving 8.84 Kb. (12.44%)]
