Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 2nd, 2017, 01:48   #1
y2kbird
Fuel Economy: 45-50mpg
Default Repurpose adblue tank into 3.8gal aux. fuel tank for more range
After reading how the fuel tank shrink due to the Adblue system in the 2015 Jetta TDI, it got me thinking... How can the 3.8gal Adblue tank repurposed (if a tune and adblue delete was done) to suppliment the 14.5gal main fuel tank? Would any of these work? -gravity feed and both tanks interconnected (if adblue tank is mounted higher than fuel tank) or -interconnect just the top of the adblue refill connector to the nearby diesel fill neck. Then connect a hose and some sort of an electric pump. or, -does the gas Jetta tank have a higher capacity due to a different shape, that might fit into a TDI as long as the adblue system was removed?
y2kbird is offline   Reply With Quote
Old July 3rd, 2017, 02:33   #2
CTD_Chevrolet
CTD_Chevrolet's Avatar
Fuel Economy: 2015:43 2002:38 mpg, 51 max
At the level of modification you're thinking about, I think it'd be a lot easier to just mount a fuel cell in the trunk.
Anything is possible, and I'm sure you could do it if you wanted to, but I don't think it would be worth it.
'15 Jetta S DSG - 30% tint, stickers
'02 Jetta 5 spd - 17/22, Race 520s, 11mm pump, ARP studs, 3" straight pipe, SBC Stage 2 Endurance w/secret sauce plate and 14lb SMF, Kerma Tuning, tons of stickers
'95 Chevy K2500 Brodozer - P Pump Cummins, Dana 60, etc, most stickers
CTD_Chevrolet is offline   Reply With Quote
Old July 3rd, 2017, 06:15   #3
turbobrick240
turbobrick240's Avatar
I don't think it's worth the hassle either. Would probably result in the interior smelling of diesel fuel.
Old July 3rd, 2017, 10:53   #4
NAZ TDI
Are you sure the 2015 tank is smaller? I just fueled up at my favorite station with the display showing I had 20 miles left. I put in 14.53 gallons. Specs for the 2015 list a 14.5 gallon tank, same as my 2011 was. So tank is the same.
Where I found a difference was when I went to swap the frame mounted trailer (bike rack) hitch. The AdBlue tank hangs down, totally blocking the right side of the frame.
NAZ TDI is offline   Reply With Quote
Old July 11th, 2017, 19:45   #5
carnotgas
carnotgas's Avatar
TDI(s): 2015 Jetta
Fuel Economy: Very Good
Default Tank Size
The 2015 Jetta tank and the 2009 Jetta tank are the same size. Only the Golf TDI has the shrunken fuel tank.
2015 Jetta S TDI Sedan, Black, Automated Dual Clutch Constant Mesh Gearbox
Avatar: Never Forget
carnotgas is offline   Reply With Quote
Old July 12th, 2017, 07:25   #6
740GLE
Ditch using the adblue tank for fuel and toss meth in it, if you are cool with tuning mind as well spend the money and get more performance!!!!
Also it'd be a pain to toss the fuel in the trunk with quite a bit of leaking.
If it was 10 gal, then I think it'd be worth it. Take a look at that greasecar spare tire tank, if you really want to cross that 1000-1200 miles before fill up line
Old August 4th, 2017, 04:59   #7
StayPuff
StayPuff's Avatar
+1. External auxiliaries like those in the bed of pickups is great.....but an auxiliary in your cabin? Ehhh, not so much
StayPuff is offline   Reply With Quote
Old August 4th, 2017, 05:14   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
My '79 Rabbit I had purchased in the late '80s had an auxiliary diesel tank in the spare tire well. It was a common thing back then when the car was new. I bought the car from the original owner, and he had it installed when the car was new. I forget the name on it, but it was a pretty nicely built piece. Had a spare tire anchor made on top of it and everything. I think it was about 5 gallons, and the car only had an 11 gal tank if I remember correctly. It had a little electric transfer pump that was operated by a switch under the dash. When the main tank got low, you just flipped the switch and you had a half tank again in a few minutes.
oilhammer
www.cardocautomotive.com
TDI Aux fuel tank Biohoward Upgrades (non TDI Engine related) 18 March 17th, 2016 04:53
19 Gallon Aux Fuel Tank wolfie1953 Upgrades (non TDI Engine related) 37 January 14th, 2016 10:42
Aux Fuel Tank hobojoker TDI 101 5 July 17th, 2009 08:03
Aux Fuel Tank 2000m2 Fuels & Lubricants 2 March 28th, 2008 09:50
vented fuel tank range MNTDIman TDI Fuel Economy 12 June 15th, 2005 09:54
Page generated in 0.13387 seconds with 11 queries
[Output: 87.43 Kb. compressed to 75.49 Kb. by saving 11.94 Kb. (13.66%)]
