Old June 30th, 2017, 13:56   #1
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Default K+N 2015 Passsat TDI Fuel filter
I've been googling for a K+N fuel filter. has anyone heard of or seen one?
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.Average 1 year 30/6/16 to 30/6/17 - 50.71 Mpg - 5.56 L/h
Jetta_Pilot is offline   Reply With Quote
Old June 30th, 2017, 14:01   #2
Owain@malonetuning
A K&N isn't going to do anything other than filter what's going into your motor worse. If it resulted in more power, the MAF values would be skewed, which are used to calculate many aspects of the motor including emissions controls. Companies have pulled their "cold air filters" off the market for these platforms because they've had so many problems with DPF failures. It would be best to use nothing but OEM components on this car if you want it to be reliable, the only worthwhile gains are from software, turbo upgrades, or exhaust modifications.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old June 30th, 2017, 14:03   #3
turbobrick240
turbobrick240's Avatar
Seriously? If you find one, don't buy it. K&N filters are sort of known for their lack of filtration. What you really want is a spin on cimtek fuel filter.
turbobrick240 is online now   Reply With Quote
Old June 30th, 2017, 16:51   #4
Jetta_Pilot
Alright I'll skip the search for a K+N fuel filter.
Reason I was looking, I bought a K+N washable cabin filter and also a cleanable K+N engine filter. Have read good reports on those.
Old June 30th, 2017, 18:51   #5
MichaelB
Reread the above post from an engine tuner. And ditch the air filter you read good reports about. K&N is a joke it's only benefit is to lighten your wallet. " A K&N isn't going to do anything other than filter the air going into your motor worse."
MichaelB is online now   Reply With Quote
Old June 30th, 2017, 19:01   #6
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Even in GTI world, people are finding that the stock intake is not a chokepoint up to around 350 hp and the stock paper filter flows just fine and filters great. Intakes and hi-flow filters are regarded as a cosmetic or auditory mod more than anything on the Mk7. Some gullible people are spending upwards of $500 for carbon fiber bling intakes and $60+ for porous filters for negligible power gains. The intake only really starts to matter at the big-turbo level or possibly with a really aggressive stage two tune.
Blue_Hen_TDI is offline   Reply With Quote
Old June 30th, 2017, 23:04   #7
adjat84th
adjat84th's Avatar
OP is talking about a K&N FUEL filter here, not air filter (though it looks like they're running one anyway). I'd doubt they carry one...but if you're looking for an upgrade, absolutely look into a 1 or 2 micron filter. User 2micron would be the one to ask if looking to go that route. A 1 micron filter that can go 100k miles between changes made a lot of sense to me.
Old July 1st, 2017, 16:40   #8
Owain@malonetuning
Whoops, didn't even know K&N made fuel filters I'd definitely install a 2micro kit for the sake of potentially saving return lines/lift pump etc in the case of pump failure.
But yeah, as above has said, the filter business is kind of a sham. Have tested several intakes, run motors without filters, installed cones and lifted them up into the air with a 1HP blower motor on them, and shy of doing that nothing has resulted in a worthwhile gain. Inlet velocity distribution is carefully measured by manufacturers for maf placement etc so they spend A LOT of time on the little details with that stuff. Only to have people rip the part off for an ebay filter
Old July 1st, 2017, 18:37   #9
Jetta_Pilot
I am not looking for any HP gain but want to be able to have a permanent engine air filter and fuel filter which only needs to be cleaned as per instructions. I spend almost 6 months in Mexico every winter and the local (50miles away) VW dealer may or may not have those filters. A friend 2-3 years desperately needed DEF fluid, it had to be special ordered (2 weeks).
I carry 2 gallons from a US truck stop with me.
A couple of days ago I changed the cabin filter and it was not dirty at all. I put a new one in though. Banged the used one against a wall and very little fell out other than some dried up small tree leaves. The K+N cabin filter and engine air filter you take it out wash it and treat it with a chemical kit from K+N and you're good to go. The cost of 2-3 filters pays for the K+N filter.
Old July 1st, 2017, 22:30   #10
adjat84th
adjat84th's Avatar
The EA288 engine air filter interval is 60k miles. That K & N sounds like a hassle (remove and clean, let dry) for not much in savings and potential MAF issues down the road. The $45-$55 for the K&N would have gotten you two OEM filters ($19/ea) that would take you to 180k miles.
The fuel filter I pictured above not only filters much better, but has 100k mile intervals, and is spin-on so keep a spare in the trunk if you need to...they're $13 if I recall (OE VW filter is $38 btw) which is dirt cheap for a fuel filter that will filter better AND last a very long time.
Old July 2nd, 2017, 08:24   #11
pdq import repair
Fuel Economy: 38.5
At a Bosch service school one time on the subject of MAF failure and K&N filters the instructor calmly stated "K&N stands for Kill it Now".
Cabin filter should be fine as only your lungs are affected.
pdq import repair is offline   Reply With Quote
Old July 2nd, 2017, 08:50   #12
tdiatlast
Oh, the mind boggles.
K & N engine air filter= greater air flow (maybe), filtering quality compromised, premature engine failure.
K & N engine OIL filter= greater oil flow, filtering quality compromised, premature engine failure.
K & N cabin filter = greater air flow, filtering quality compromised = premature lung failure.
Perfect planned obsolescence! 1970s GM engineers would be proud!
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old July 3rd, 2017, 08:24   #13
740GLE
Common now, don't pretend VW isn't on the planned obsolescence band wagon now. 150K and that's is.
Old July 3rd, 2017, 12:18   #14
tdiatlast
740GLE: Of course, you're right.
K & N oil filter just makes me laugh, though.
Old July 3rd, 2017, 14:51   #15
Jetta_Pilot
It's all fine and dandy to throw around that the filter is only $ 19.00 each.
That may be in the U S of A but not in Canada. A Mahle filter which I just installed today was Cdn $ 60.00 !
BTW: The filter I took out was clean as a whistle, there was NO crud in the bottom of the filter housing either and that is after spending 5 1/2 months last winter in Mexico and getting the least expensive Diesel fuel at home.
fuel filter for 2015 larrydk VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 12 July 17th, 2017 17:25
2015 GSW Fuel Filter part #? roberthaas VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 May 20th, 2016 18:02
BEAUTIFUL 1996 VW Passsat TDI 45MPG! Alabama bhays4 TDI Cars for Sale/Wanted 9 September 23rd, 2015 23:07
2015 Jetta TDI Oil Filter Location Mark Hubley VW MKVI-A6 Jetta Sedan (~ 2011+) 8 April 28th, 2015 13:08
96 Passsat Rough Idle kneebull VW MKIII-A3/B4 TDIs 9 November 24th, 2003 12:03
Page generated in 0.19138 seconds with 11 queries
[Output: 132.97 Kb. compressed to 111.23 Kb. by saving 21.75 Kb. (16.36%)]
