Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 30th, 2017, 09:39   #1
bennyrz
Default car place says i need to replace the whole compressor... true/false?
They say the valve has a bunch of debris in it, and its actually built into the compressor now so can't just replace it, need to replace the whole compressor..is this true?
2011 jetta tdi
bennyrz is offline   Reply With Quote
Old June 30th, 2017, 11:24   #2
vtbigdog
Pardon my ignorance, but what is a 'car place'? Midas Muffler, Oil N'Go, a VW dealer, or none of the above?
vtbigdog is offline   Reply With Quote
Old June 30th, 2017, 11:28   #3
JSWTDI09
JSWTDI09's Avatar
Often the whole compressor does not need to e replaced. Begin reading here: http://forums.tdiclub.com/showthread.php?t=284611
The trick is that you need to find a place that will replace the valve. VW dealers do not sell the valve - they only sell complete compressors (there is a lot more money in replacing the entire compressor.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old June 30th, 2017, 11:43   #4
bennyrz
a european car specialist, "Our specialty is the service, repair and maintenance of the top European vehicle makes like Audi, BMW, Land Rover, Mercedes, Porsche, Volkswagen & Volvo."
Old July 3rd, 2017, 11:13   #5
NAZ TDI
That link that JSWTDI09 provided is correct. I replaced that valve in mine 2 years ago and it has worked great. I ordered it from the place in Florida also. I did find a website where you could order direct from China for about $25 and wait a couple weeks.
It's easy to change-just drop the lower cover and it's right there. No need to remove compressor. No reason your "specialist" couldn't do it for a reasonable charge. I can see them not wanting to give a warranty on the job, but that's only fair.
NAZ TDI is offline   Reply With Quote
Old July 4th, 2017, 08:43   #6
jetlagmech
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
The valve has debris.....what valve ? The valve in the compressor is called RCV (Refrigerant Control Valve). There is a screen on it and if there is debris in it then the compressor probably does need changed and the system flushed, and will usually need a dryer also.
But some shops will not change just the RCV because its not in the parts book. I had trouble finding a shop to change my RCV several years ago. But when I found one, it fixed my A/C. But the screen on my RCV was clean. This has been a very common problem.
JETLAGMECH
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old July 6th, 2017, 16:36   #7
tomo366
TDI Lifer
tomo366's Avatar
I took my ex 2010 Jetta Sportwagen to VW And they wanted over $900 to replace the Compressor I had GEICO Extended warranty I had to pay 250 deductible and they were going to put. Rebuilt on it I ended up paying another 100+ to get new
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
True or False? McGuillicuddy TDI 101 18 May 1st, 2014 05:54
True or False jdennison TDI 101 3 February 28th, 2011 23:54
Tiptronic: True or False RT1 VW MKIV-A4 TDIs (VE and PD) 5 May 17th, 2007 10:10
True or False (CEL/MAF) Dan_Powell VW MKIV-A4 TDIs (VE and PD) 2 December 29th, 2004 08:00
True or False BeerDrinker VW MKIV-A4 TDIs (VE and PD) 12 July 19th, 2004 14:31
Page generated in 0.13917 seconds with 11 queries
[Output: 78.26 Kb. compressed to 67.90 Kb. by saving 10.37 Kb. (13.24%)]
