Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 6th, 2017, 14:57   #31
y2kbird
Fuel Economy: 45-50mpg
Originally Posted by turbobrick240 View Post
2009 and up (common rail ) have the not so good cp4 hpfp. I now have a cp3 hpfp kit from 2micron on my 2011 golf. Unlike the cp4, the cp3 is a well engineered design. My car should easily see 300k miles with the mods I've done.
Does the 2015 Jetta TDI (with ea288 engine) use this same weak/flawed CP4 fuel pump?
y2kbird is offline   Reply With Quote
Old July 6th, 2017, 18:19   #32
turbobrick240
turbobrick240's Avatar
Yes, but they claim to have solved the problem(I'm skeptical). But, so far there don't seem to be very many failures on the ea288 cars.
HPFP Failure, system replaced - follow up problems pjschaff TDI 101 5 September 14th, 2014 12:07
2011 HPFP Failure - Fuel System Replaced Under Warranty speedeep VW MKVI-A6 Jetta Sedan (~ 2011+) 54 September 12th, 2013 16:32
Replaced entire clutch system, now no start. Suspect clutch sensor. saucer VW MKIV-A4 TDIs (VE and PD) 10 October 6th, 2012 12:57
Aux Fuel Pump Failure (Formerly:HPFP Failure!) EOTS VW MKV-A5 Golf/Jettas 35 February 15th, 2012 07:06
Poping sound from front end after Stealership replaced engine due to BS Failure! bestsasco VW B5 Passat TDIs 5 December 25th, 2011 17:45
Page generated in 0.12308 seconds with 11 queries
[Output: 54.90 Kb. compressed to 50.81 Kb. by saving 4.09 Kb. (7.45%)]
