Old August 12th, 2015, 15:30   #46
turbobrick240
turbobrick240's Avatar
I'm in the same boat. I no longer need a low saps oil for my car, and haven't quite decided if I should get more formula m esp, regular formula m, or a CJ-4 oil. Right now I'm leaning toward the latter based on cost and availability.
Old August 12th, 2015, 15:55   #47
PhotoWrite
Is there a regular Formula M and a Formula M ESP? Not sure I know or was aware of the difference.
www.RoadTraveler.net
PhotoWrite is offline   Reply With Quote
Old August 12th, 2015, 17:05   #48
turbobrick240
There definitely used to be both flavors of formula m. Maybe it was the non esp version that was discontinued. Not sure. The esp is mb229.51 and the non esp is mb229.5.
Old August 12th, 2015, 17:09   #49
PhotoWrite
Doing a bit more research it appears I screwed up and ordered the regular Formula M [I didn't realize there was a difference], and not the ESP version...
It's after hours in PA at the dealership where the oil is coming from, but I'm using every possible option to cancel the oder before it ships!
Back to decideding on my next oil to use
Old August 12th, 2015, 17:42   #50
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Mobil 1 Delvac ESP 5W40
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old August 12th, 2015, 18:13   #51
PhotoWrite
That version has more Suphated Ash than I'm looking for.
Old August 12th, 2015, 19:23   #52
turbobrick240
Amazon has 5L jugs of Ardeca 5w-40 mb229.51 for $50 shipped. I bet you'd be plowing new ground here with that oil. Probably a great oil.
Old August 12th, 2015, 20:28   #53
PhotoWrite
http://www.amazon.com/dp/B00DOV2PTG/...Q3D8TXKU&psc=1
Actually this Kendall has my attention for an oil with 0.78% sulfated ash. I can get it from a local oil warehouse where I have an account, but this Amazon price is good too.
Old August 13th, 2015, 07:36   #54
turbobrick240
Looks like a good oil at a very good price. The mobil1 esp 5w-30 is actually a great oil as well.
Old August 13th, 2015, 10:19   #55
PhotoWrite
Yep, I'm also considering Mobil 1ESP 5w30, though the price of that Kendall plus my historical and usage bias toward 5w40 has the Kendall in first place to replace the ESP Formula M in our JSW TDI. Kendall makes a 5w30 version too, both have a suphated ash of 0.78.
Old July 12th, 2017, 15:07   #56
Fumes
I know that it's been a while since there were any comments on this subject, but can the 5W40 Mobil ESP Formula M be used on a 2006 BEW diesel?
Fumes is offline   Reply With Quote
Old July 19th, 2017, 15:27   #57
Drivbiwire
Zehntes Jahr der Veteran
Yes, but the best oil has proven to be the Mobil 1 Turbo Diesel Truck 5w40, I routinely have customers running anywhere between 15,000-25,000 miles on oil changes WITHOUT CAM FAILURES.
Some of them have the original cams at 425,000 miles, all running 15,000+ mile oil changes on the M1 TDT 5w40.
The issue was never the cam, but SHORT OIL CHANGE INTERVALS (less than 10,000 miles) or using 5w30 or oils that lacked the heavy duty EP/HP wear additives like M1 TDT has.
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old July 23rd, 2017, 13:43   #58
TooSlick
TDI(s): Audi 100S
Fumes,
The VW Spec Uber Lubes are generally backwards compatible, yes.
TS
TooSlick is offline   Reply With Quote
Mobil 1 ESP Formula Derrel H Green Fuels & Lubricants 181 December 20th, 2015 07:52
mobil 1 5w30 esp formula - Hamilton danielsza Ontario 14 June 9th, 2014 18:20
Mobil 1 ESP 5w-30 or Mobil1 ESP Formula M 5w-40? spyderhead Fuels & Lubricants 8 September 21st, 2009 08:56
Mobil 1 Formula ESP 5W-30. lhd65bug Fuels & Lubricants 2 February 13th, 2008 07:11
Mobil 1 ESP Formula M 5W-40 Mass. Wine Guy Fuels & Lubricants 23 January 10th, 2007 06:49
Page generated in 0.15628 seconds with 11 queries
[Output: 112.50 Kb. compressed to 94.13 Kb. by saving 18.37 Kb. (16.33%)]
