Old November 19th, 2014, 22:17   #31
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
I'm at least a year away yet from running out my warranty so time is on my side to sort out what oil to use.
For the record I just ordered some Liqui-Moly Top-Tech 4200 5W-30 from IDParts.
http://www.idparts.com/catalog/produ...oducts_id=2472
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old November 21st, 2014, 10:23   #32
740GLE
Still have an oil change worth when I stock piled at a Napa sale over two years ago. boy to the miles fly by, never thought 16qts of ESP 5w40 would have me looking for more oil this soon.
Time to see if VIP will hide all the M ESP 5w30 again this black friday!
Old November 25th, 2014, 14:10   #33
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
FYI for folks...
http://forums.tdiclub.com/showthread...57#post4673957
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old November 30th, 2014, 12:22   #34
PhotoWrite
Default Bummer
After selling our 2000 Golf TDI and buying a '13 JSW last summer I decided to use the Formula M because the oil I was using in the old 1.9L was not okay for the 2.0L.
Based on my own bias, knowledge, and research that included a member here having driven about 150k [my memory], the Formula M seemed like a great though expensive, premium choice for my application and use. I purchased enough 6-packs from Amazon to cover the first few oil changes, and now need to decide if I should stock-up to take the car further, or just deal with the inevitable and find a new product.
Interesting timing of my [late] discovery that Formula M 5w-40 has been discontinued… I was actually thinking about researching if this very low ash oil would possibly be a good choice for my ’14 Ram/Cummins… Probably not regardless, and it looks like I’ll just stick with Delo 400 for the truck, a good, easy, and inexpensive choice.
www.RoadTraveler.net
PhotoWrite is offline   Reply With Quote
Old November 30th, 2014, 12:54   #35
tdiatlast
I haven't read this entire thread recently, this may have been discussed, but do I remember correctly that there isn't a huge difference between the ESP 5-30 and the ESP M 5-40?
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old November 30th, 2014, 12:55   #36
PhotoWrite
I believe you are correct (from memory).
Old November 30th, 2014, 13:44   #37
jhinsc
Probably correct, but if you go to Mobil's website and look up the oil by make/model of car, the only oil that is recommended is their 5w-30. The 5w-40 is only spec'd for MB's. Both descriptions state they're low ash, but only the 5w-30 shows it's VW 507 spec'd.
jhinsc is offline   Reply With Quote
Old November 30th, 2014, 17:48   #38
tdiatlast
Yes, only ONE ESP oil has VW 507 approval. What I remember is that the viscosity of the 5w-30 was more like 5w-37?
Old November 30th, 2014, 18:58   #39
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
The SAE viscosities do not follow that kind of logic. A 30 weight is defined over a range of of viscosity in cSt and a 40 weight over another range over the 30 weight. A "37" therefore doesn't really make much sense; it will be either 30 or 40, but some manufacturers do not grade the weights on the product label in strict adherence to the viscosity range defined by SAE J300. This is uncommon in engine oils but seen more in gear oils. One can say, however, that oil "x" is, for example, a thin or thick 30 weight depending on where the viscosity @ 100C lies within the range that defines the weight.
Old November 30th, 2014, 19:51   #40
tdiatlast
Does it make more sense to say that the ESP 5w-30 is more like a 40 weight than a 30 weight?
Old November 30th, 2014, 19:56   #41
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Mobil 1 ESP Formula 5W-30
SAE Grade 5W-30
Viscosity, cSt (ASTM D445)
@ 100șC 12.1
@ 40șC 72.8
Viscosity Index 164
Sulphated Ash, wt% (ASTM D874) 0.6
HTHS Viscosity, mPa•s @ 150șC (ASTM D4683) 3.58
Pour Point, șC (ASTM D97) -45
Flash Point, șC (ASTM D92) 254
Density @15.6 șC g/ml (ASTM D4052) 0.850
This in the higher range of the 30 weight. it's below the threshold of what would qualify as a 40 weight.
Old November 30th, 2014, 19:58   #42
jhinsc
Or at least 5w-35?
Old November 30th, 2014, 19:59   #43
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Sigh.... IT DOESN'T MAKE SENSE!!!
Old December 2nd, 2014, 20:52   #44
turbobrick240
turbobrick240's Avatar
I believe the M1 esp 5w-30 product would be best described as a very robust, heavy 5w-30. It is made in europe, and comes in liters rather than quarts. All around great oil for our cr tdi's.
Old August 12th, 2015, 15:59   #45
PhotoWrite
Default NOS or brought back?
As my current stock of Formula M is getting low, I've been shopping for a replacement/future oil for our '13 JSW TDI. I was ready to pull the trigger on Kendall Euro GT-1 [with others in contention] when I was surprised to find 6-packs of Formula M for sale on Amazon [not from Amazon like before].
Doing research yesterday I also noted that Mobil does still list Formula M on their site under the ESP category, with the other weight oils...so was it discontinued, brought back, or just hard to find here in the USA? Either way I'm happy to have a couple more oil changes covered with oil on the shelf.
Mobil 1 ESP Formula Derrel H Green Fuels & Lubricants 181 December 20th, 2015 08:52
mobil 1 5w30 esp formula - Hamilton danielsza Ontario 14 June 9th, 2014 19:20
Mobil 1 ESP 5w-30 or Mobil1 ESP Formula M 5w-40? spyderhead Fuels & Lubricants 8 September 21st, 2009 09:56
Mobil 1 Formula ESP 5W-30. lhd65bug Fuels & Lubricants 2 February 13th, 2008 08:11
Mobil 1 ESP Formula M 5W-40 Mass. Wine Guy Fuels & Lubricants 23 January 10th, 2007 07:49
Page generated in 0.18088 seconds with 11 queries
[Output: 130.52 Kb. compressed to 108.88 Kb. by saving 21.64 Kb. (16.58%)]
