Old November 7th, 2014, 13:29   #16
mjwilson
Well this sucks. Been using ESP Formula M 5w40 since I switched at 100K on my car ('04 Jetta). Now at 265K and cam and lifters are pristine. Guess I'll try Mobil 1 TDT as most folks seem to have pretty good wear numbers with this oil. I've always liked Motul Specific 505 01 since I had the car but it got to hard to find and too expensive. Any adverse thoughts to going with TDT?
2015 Passat SE (bought back 11/25/2016)..adieu
mjwilson is offline   Reply With Quote
Old November 7th, 2014, 13:47   #17
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
None at all. TDT has a good track-record. Also, you might find Valvoline MST 5w40 that is 505.01 in stores.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old November 7th, 2014, 15:15   #18
Tarbe
Suck city.....
Two VWs sold back...see 'ya later. Maybe...
Tarbe is offline   Reply With Quote
Old November 7th, 2014, 15:17   #19
yatzee
yatzee's Avatar
TDI(s): see sig
M1 0w40 euro is good for ALH's and nice and cheap at maomart
2005 C230 6 spd, 2001 GMC LB7 w/ZF6, 1994 E280 5 spd, 1990 500SL and some euro 16v stuff. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
Old November 7th, 2014, 18:03   #20
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
Yup, add msg # 11 to M1 TDT 5w40 and/or Mobil Delvac 1 5w40. Like yours the cam and innards are pristine. I run 30,000 miles OCI's.
ruking is offline   Reply With Quote
Old November 14th, 2014, 12:32   #21
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Available from Amazon now:
http://www.amazon.com/gp/product/B00...A2KP3IL9AY5EQ9
BITOG thread on this oil:
http://www.bobistheoilguy.com/forums..._1_X1_ESP_0W30
Old November 15th, 2014, 21:48   #22
FJR1300
Originally Posted by Bob_Fout View Post
Just a PSA for those who are using this oil.
http://www.mobiloil.com/USA-English/...a_M_5W-40.aspx
From the Mobil website:
Discontinued - Mobil 1 ESP Formula M 5W-40 is being replaced by Mobil 1™ ESP X1 0W-30.
With this development would it be safe to assume that I would get nods of agreement and approval that it would be a prudent course of action to utilize Mobil 1 ESP 5W-30 which is on the VW approved list for 504 00/ 507 00 oils for my brand new 2015 Golf TDI SE with 6 speed manual transmission when it rolls up on it's 10,000 mile oil change and that looking for a batch on sale and storing it in my garage would not be a bad idea?
FJR1300 is offline   Reply With Quote
Old November 15th, 2014, 22:17   #23
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Yes- use VW507 for your 2015 tdi. No need to stockpile. They haven't changed that oil, only the 5W40 version that was designed for MB diesels with DPF.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old November 18th, 2014, 11:33   #24
tikal
Fuel Economy: 37 MPG (~ 45% city)
What is the main reason(s) that Mobil 1™ ESP X1 0W-30 is not a VW 507 oil?
By reading its tech specs in terms of viscosity and HTHS it is so close to Mobil 1 ESP 5W-30 (I have not be able to find the TBN for the 5W-30 oil at this point).
tikal is offline   Reply With Quote
Old November 19th, 2014, 10:51   #25
turbobrick240
turbobrick240's Avatar
Cool
Bummer, i really liked the formula m for my 2011 common rail! I guess the 507 esp 5w-30 is my next oil. I wonder if those who have removed the dpf continue to use the low SAPS oils, or go to the more available and cheaper cj4 5w 40 diesel oils. Also if there are other good 5w 40 options that meet mb 229.51. I have heard good things about pennzoil ultra euro 5w 40, but dont think it is low SAPS.
Old November 19th, 2014, 16:29   #26
turbobrick240
I googled 5w-40 mb 229.51 oils and found a pretty extensive listing. Apparently the majority of 229.51 oils are 5w-30. But also dozens of 5w-40, 0w-40, and 0w-30 oils listed. I am now very interested in mobil 1 esp 0w-40 if i can find it. Valvoline synpower mst 5w-40 looks interesting, but at $9/quart it is a bit pricey. If i stock up on the formula M, will it degrade over a period of say 5 years?
Old November 19th, 2014, 16:40   #27
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
If you keep it sealed and in more-or-less climate controlled conditions (indoors), it'll be fine.
https://www.mobiloil.com/USA-English...helf_Life.aspx
Old November 19th, 2014, 17:12   #28
turbobrick240
Sweet, thanks Bob. That was my gut feeling. I think i will stock up for another 9 changes, by then i will probably want to try something else.
Old November 19th, 2014, 20:47   #29
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
What is the consensus on Delvac-1 5W-40 ESP for a VW CR engine?
http://www.mobil.us/usa-english-lcw/...-esp-5w40.aspx
I'm thinking about using this oil after my engine warranty expires. I know it doesn't carry any VW specs but I think that point is academic. If this oil can handle modern EGR/DPF/DOC/DEF emission systems in the big rigs then it should be able to be safe to use in anything VW makes.
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is online now   Reply With Quote
Old November 19th, 2014, 20:50   #30
yatzee
yatzee's Avatar
TDI(s): see sig
Bob, the oil king will chime in, but if I'm not mistaken, the Ash level is too high - the specs in the link you posted show it at 1.0, and 507.00 need less than that. For instance, the 5w40 ESP that's being cancelled is at .6 %.
It would be fine if you were using your car off road on your own personal property, but the higher ash level *could* cause DPF issues
Mobil 1 ESP Formula Derrel H Green Fuels & Lubricants 181 December 20th, 2015 07:52
mobil 1 5w30 esp formula - Hamilton danielsza Ontario 14 June 9th, 2014 18:20
Mobil 1 ESP 5w-30 or Mobil1 ESP Formula M 5w-40? spyderhead Fuels & Lubricants 8 September 21st, 2009 08:56
Mobil 1 Formula ESP 5W-30. lhd65bug Fuels & Lubricants 2 February 13th, 2008 07:11
Mobil 1 ESP Formula M 5W-40 Mass. Wine Guy Fuels & Lubricants 23 January 10th, 2007 06:49
Page generated in 0.17408 seconds with 11 queries
[Output: 134.71 Kb. compressed to 113.35 Kb. by saving 21.37 Kb. (15.86%)]
