Old September 28th, 2013, 08:24   #1
wncre8r
TDI(s): 2
Default '03 wagon shuts down and resets clock and trip odometer
I am having an intermittent problem with an '03 wagon. It shuts down while driving and in doing so the clock and trip odometer reset but not the radio. I have to pull over and turn the key back to off and start again. Any Ideas? The battery terminals are tight. This has happened 3 or 4 times in the last month
wncre8r is offline   Reply With Quote
Old September 28th, 2013, 08:55   #2
Genesis
Fuel Economy: 53/48/42
Check the primary fuses (on top of the battery) and the ground lead at the engine block end. Good bet it's the negative cable that has the problem.
Genesis is offline   Reply With Quote
Old September 28th, 2013, 09:10   #3
flee
Fuel Economy: 40-ish
Also, how old is the battery?
I had the same symptoms and later needed a new battery.
flee is offline   Reply With Quote
Old September 28th, 2013, 14:34   #4
AndyBees
AndyBees's Avatar
Loose or poor connection somewhere!
Has the problem caused any issues with the radio? If not, the problem is not the battery or battery terminals nor the circuit that involves power to the radio! Otherwise, you would be looking for the radio code in order to re-set it.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old September 28th, 2013, 15:01   #5
Genesis
Andy: Nope. The radio will not lock if the ECU and radio combination remains the same. I've pulled my battery for over 24 hours before while doing work on the car and did not need the code -- it checks the ECU serial number and if the same it comes right back up.
Old September 28th, 2013, 16:30   #6
Rxfire
Rxfire's Avatar
Andy and Genesis--
Same here, never had to use a radio code when pulling batteries with any of our 03's.
I was all worried, maybe they changed it somewhere in the 2000-2003 years
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old September 28th, 2013, 19:47   #7
mittzlepick
mittzlepick's Avatar
Fuel Economy: 1175 record tank
relay 109? ignition switch?
mittzlepick is offline   Reply With Quote
Old September 28th, 2013, 20:14   #8
AndyBees
AndyBees's Avatar
Never had to use Radio code either due to pulling battery. But, I have as a result of the negative cable losing connection as I hit the ignition to start the engine.. had that to happen a couple of times about 18 months ago!
It's a bad connection somewhere! Obviously, it is not just affecting the engine, it's hitting the power to the Cluster (which is Computer).
Old September 29th, 2013, 04:58   #9
Rxfire
Rxfire's Avatar
Thanks for the clarification Andy, something to be aware of....
Old September 29th, 2013, 09:06   #10
wncre8r
TDI(s): 2
so should I be looking for a loose neg terminal cable at the block or should I concerned about a 109 relay or ignition switch problem, what would be your best guess. why would it be intermittent and why would it only affect the trip odometer, clock on dash and shut the engine off?
Old September 29th, 2013, 09:11   #11
Genesis
I doubt it's relay 109 as that wouldn't kill the cluster.
I'd be looking for a loose primary power connection and the most-likely is the negative cable -- but it of course can be either of them.
Be aware that you can have corrosion INSIDE the cable jacket; if that is going on it is detectable by flexing the cable along its length -- if you feel "cracklies" when you do that it's a good bet the cable has wicked up salt and other corrosives into the jacket and the wire has been compromised internally and should be replaced.
Old September 29th, 2013, 09:27   #12
wncre8r
TDI(s): 2
took off and cleaned the neg terminal at the block and also at the battery. looked at the fuses in the battery box, they look fine. Will see if that solves the problem. what does the 109 relay do?
Odometer (Not Trip-meter) resets itself Agontyr VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 18 January 13th, 2012 10:24
Trip odometer resets to zero and clock to 12:00 at each start dennisy TDI 101 3 November 6th, 2009 10:08
Trip odometer automatically resets itself? ddafforn TDI 101 6 September 16th, 2009 10:24
Help, Odometer, trip odometer and clock blank and run car MadDogBrenner TDI 101 2 February 19th, 2009 15:33
Clock & Trip Odometer Resets freedom3 TDI 101 11 February 23rd, 2004 14:39
Page generated in 0.15121 seconds with 11 queries
[Output: 106.42 Kb. compressed to 89.44 Kb. by saving 16.99 Kb. (15.96%)]
