Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old January 11th, 2017, 09:22   #406
sandmansans
TDI(s): 2014 Jetta
Fuel Economy: Best tank:54.7. Drove From Chattanooga Tennesse to Poconos PA
*mod please delete, didn't post correctly*
sandmansans is offline   Reply With Quote
Old January 20th, 2017, 11:21   #407
SkeeterMark
SkeeterMark's Avatar
Fuel Economy: See Sig
2011: (16 cars)
300,000 mi 05/03/16 dozenspeed v.: 6mt prm owner: 1 tb: 3 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 2 note: oil ash 258ml@269,962 mi-horn: 3 turbo: 2 @256,646
229,000 mi 06/15/15 canuck07 v.: dsg hl owner: 1 tb: 2 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 2 note: rear brakes @ 205k mi due to stuck passenger side calliper
220,000 mi 08/29/16 rtking v.: dsg prm owner: 1 tb: 2 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: malone dsg tune; dsg cracked at 160k but not yet repalaced, battery replaced at 186k, 4th set of tires (michelin pilot sports a/s3)
155,000 mi 02/16/15 sssteve04 v.: 6mt prm owner: 2 tb: 2 dpf: 1 hpfp: 2 ef: 1 fb: 1 rb: 2 note: hpfp done at 116k
130,000 mi 06/15/15 mwayner69 v.: dsg le owner: 1 tb: 2 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
110,455 mi 06/26/15 mac5155v.: dsg bse owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: dmf @ 96k miles
100,000 mi 11/19/14 phalls4tdi v.: 6mt prm owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: all stock-a few electrical bugs-i push engine/turbo regularly.
90,770 mi 11/30/16 pdt165 v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: malone stage 1.5 tune: Sold Back to VW
90,500 mi 01/02/15 leonvfb v.: dsg prm owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
80,000 mi 12/04/15 torrimacv.: dsg le owner: 1 tb: 1 dpf: na hpfp: 1 ef: na fb: 1 rb: 1 note: ecs fogs-euroswitch-underseat drawers-dpf+egr delete-malone stage 2+dsg tune-buzzken down+straight pipes to oe muffler-traction control off button
75,600 mi 01/30/14 sydneycb v.: dsg hl owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: replaced: Windshield, fog lights-3rd set of summer tires
70,726 mi 09/17/15 ddt716 v.: 6mt cl owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: bought cpo july 16-1st fuel-up:553.6 miles @ 41.4 mpg, best: 713.3 miles @ 48.9 mpg
65,244 mi 07/24/13 savageman69 v.: 6mt hl owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
30,000 mi 01/05/14 jack diesel v.: dsg prm owner: 2 tb: 1 dpf: na hpfp: 1 ef: 1 fb: 1 rb: 1 note: malone stage 2-diesel dubs 2.5' dp & midpipe w/resonator
29,575 mi 04/05/15 brewmaster v.: dsg cl owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: o2 sensor: 3 (9k, 23k)-unitronic stage 1 tune-dsg tune
104,231 mi 05/18/16 snowmobileaddict v.: dsg prm owner: 2 tb: 1 dpf: 2 hpfp: 1 ef: 1 fb: 1 rb: 1 note: vw paid 50% of cost for dpf and egr filter replacement this week after failure outside of fed warranty
2012: (22 cars)
128,000 mi 05/27/16 biz v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: broken lf coil spring 121k (ka-pow!); on 3rd set of tires; original brakes; no other mechanical issues so far.
121,500 mi 10/10/16 rabbid0281 v.: 6mt se owner: 1 tb: 0 dpf: na hpfp: 0 ef: na fb: 1 (312mm rotors) rb: 1 note: egt sensor:2, best tank 744.7 mi on 13.8 gallons on stock intake, malone stg 3+, cr170 turbo, southbend stage 2 endurance clutch(sucks), and buzzken 2.5" turbo back with resonator(all mods installed at 88k)(purchased 01/03/12) 53.69mpg (zinkwerks), 145mph, transmission at 116k - Buyback in Dec. DO NOT USE SHORT SHIFTER, OEM ss is okay
102,368 mi 11/05/15 stlvwconvert v.: 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: outside sale road warrior
83,000 mi 12/07/13 2pt. Slo v.: 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: best tank 673
75,103 mi 05/16/14 scoutx v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: hail-damaged@9mi-smashed by tree@13,306-nav@32,244-windshield(rock)@62,462 (replaced@72,863-1k mi tank/61.3mpg@75,026
72,100 mi 10/10/14 bohica1 v.: 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
69,469 mi 04/03/16 akjdouglass v.: Dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: replaced: Bluetooth module; wiper motor @40k
66,100 mi 01/02/15 bigwhitebeast v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb
57,500 mi 06/18/16 snieseldiesel v.: 6mt owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
56,000 mi 07/24/13 fon462 v.: 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: horn: 2
55,000 mi 09/25/14 solid19snake v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
51,400 mi 02/14/14 jetta rhody v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb-also replaced: Windshield, rear bumper kessy antenna
41,000 mi 02/04/14 engineers<3diesel v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: replaced:radiator @30k, ic tsb@39.5k miles
38,500 mi 05/02/14 purplegrimace v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb
31,000 mi 07/24/13 cndtdi v.: 6mt cl owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb
30,000 mi 08/08/13 thiggins v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
29,080 mi 07/24/13 pstroms v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
29,000 mi 07/23/13 jetta12tdi v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
28,500 mi 11/22/14 lance2214 v.: dsg prm owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: bought salvage & restored w/10k mi- resurrected to glory 8/30/13
25,457 mi 02/20/14 ironman11142 v.: 6mt owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: purchased 11/23/2013
22,200 mi 02/27/14 jayg v.: 6mt bse owner: 1 tb: 1 dpf: 2 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb 1/11/14-vw buy-back-lemon law 2/26/14
138 mi 03/16/14 joe schmoe v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: yes mileage is correct, bought new 3/14/14!
2013: (22 cars)
122,500 mi 01/20/17 skeetermark v.: 6mt prm owner: 1 tb: 2 dpf: 1 hpfp:
1 ef: 1 fb: 1 rb: 1 bat: 2 note: 2013.0-ic tsb
100,006 mi 04/18/16 tjdeerslayer37 v.: 6mt prm owner: 1 tb: 1 dpf: 2 hpfp: 1 ef: 1 fb: 1 rb: 1 note: dpf@21k-dpf delete malone stage 2 @~35k
92,100 mi 07/08/16 fireitup v.: 6mt prm owner: 3 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: AC Compressor replaced at 90k service
86,531 mi 06/14/16 rico227 v.: dsg owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
82,000 mi 08/13/13 markanthony v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: mileage not a typo, i'm a medical courier.
70,000 mi 04/26/15 atenza_freak v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 2 fb: 1 rb: 1 note: horn: 2 -new set of tires, winter tires, passenger drl
43,000 mi 01/31/14 fastpete v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb
43,000 mi 04/15/15 rdc98tdi v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb-malone stage 1.5-bought 9-13-13
38,000 mi 08/30/15 chitownpilot v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 43mpg combined average
58,404mi 8/21/16 millerman61 v.: dsg prm owner: 1 tb: 2 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ic tsb
36,500 mi 10/17/14 paulman v.: dsg bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: diesel kleen grey every tank
36,325 mi 04/21/15 bjs02 v.: 6mt prm owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ac control button sticking, warranty replaced @ 20k service
30,980 mi 07/31/14 locnar v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 2013.5-ic tsb
30,600 mi 05/17/15 pressenter[] v.: 6mt bse-nav owner: 1 tb: 1 dpf: 2 hpfp: 1 ef: 1 fb: 1 rb: 1 note: Dpf replaced at 22k mi
28,000 mi 02/02/14 tdi_apprentice v.: 6mt bse owner: 1 tb: 1 dpf: na hpfp: 1 ef: 1 fb: 1 rb: 1 note: stage 2 malone 6/13 @10,000mi
22,000 mi 08/13/13 bwhite757 v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 2013.5-delivery 4/21/13 @123mi, bowling alley computer tech
20,500 mi 11/22/14 lance2214 v.: dsg prm owner:2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: bought salvage & restored w/400mi (i know brand new), resurrected to glory 6/30/13
13,172 mi 08/17/15 993er v.: 6mt cl owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: totally stock.
12,652 mi 06/16/14 packethauler v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 2013.5
9,650 mi 02/15/14 thealer v.: 6mt prm owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
8,100 mi 04/20/14 dudgy v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: warranty repaint of front bumper chipping @7258 mi
6.496 mi 01/06/14 japedo v.: 6mt cl owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
2,128 mi 09/01/13 cybear male v.: dsg owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
2014: (14 cars)
101,000 mi 03/05/16 sandmansans v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: sticking fuel door recall performed. Underseat drawers installed. Bosal euro hitch. Westfalia euro trailer electric kit with t-esp. Traction control kit installed. LED DRL install. Ostram Rallye 65W installed, both high and low beam. O2 Sensor replaced at 93,000.
51,100 mi 09/22/15 ranger50 v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:~45 mpg
13,139 mi 09/24/14 fowvey v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: ac compressor replaced 13k
7,600 mi 08/28/14 fenderplayer v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: driver seat squeak >3k-lucas fuel stabilizer/lube from 2,500mi
7,300 mi 07/14/14 dyates442 v.: dsg bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 45 mpg avg.
4,400 mi 01/10/14 livefreeordie89 v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: bad speaker wire at 500 miles
3,900 mi 01/26/14 pete's_tdi v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 2 bad aux pumps, fuel lines reversed at the factory
2,800 mi 11/03/14 senez v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 47.2 mpg best tank
2,100 mi 07/03/14 maxst2 v.: 6mt bse owner:
1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: bought with 40miles 4 weeks ago:d
1,693 mi 11/15/13 campos v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 45.2 mpg best tank
1,580 mi 06/13/14 dieseldave359 v.: 6mt bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
1,100 mi 08/26/14 fortyfive1911a1 v.: dsg prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 500+ miles a week
972 mi 11/19/13 miahallen v.: 6mt prm owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
355 mi
01/22/14 ytjetta v.: dsg bse owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
2015: (7 cars)
19,000 mi 11/24/15 Rodmiser v.: bse dsg owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 44.6 mpg
18,100 mi 01/10/17 16vjohn v.: 6MT BSE owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: Purchased 3/20/15, 46.1mpg
8,804 mi 08/28/15 ntwrkd v.: sel 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: purchased 4/08/15 42.9mpg
2,401 mi 05/22/15 hotrodtractor v.:
sel 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: purchased 4/30/15 44.3mpg
1,151 mi 05/23/15 rodmiser v.: bse dsg owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 44.6 mpg
10 mi 06/30/15 gcoop v.: sel dsg owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: purchased 6/30/15
2600 mi 11/24/15 thatredmk6 v.: cl 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: purchased 9/15/15, dressed up;window tint, matte black roof wrap, h&r racing springs, black skirts, black lip spoiler (trunk), piano black 18'' vw sport rims
please review post #1 before making your first entry
*****Please create a new post from the most recent posted data rather than update your previous post, or else the system gets messed up, thank you.*****
SkeeterMark is offline   Reply With Quote
Old March 27th, 2017, 21:58   #408
rtking
2011: (16 cars)
241,060 mi 03/27/17 rtking v.: dsg prm owner: 1 tb: 2 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: malone dsg tune; dsg cracked at 160k but not replaced, battery replaced at 186k, 5th set of tires (Michelin Pilot Sport AS3+), Sold back to VW 3/27/2017
229,000 mi 06/15/15 canuck07 v.: dsg hl owner: 1 tb: 2 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 2 note: rear brakes @ 205k mi due to stuck passenger side caliper
2012: (22 cars)
2013: (22 cars)
2014: (14 cars)
355 mi
2015: (7 cars)
2011 Jetta TDI w/DSG & Nav: White Gold over Cornsilk leatherette. 240,000+ miles of trouble-free driving. Buy-back completed March 27, 2017
rtking is offline   Reply With Quote
Old April 24th, 2017, 12:57   #409
Rodmiser
Fuel Economy: 47 MPG last 10 tanks & 57 MPG BEST
30192 mi 04/11/17 rodmiser v.: bse dsg owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: 44.8 mpg warranty 1 valve 04L-131-113-G 1 supply lin 5C0-131-B AD Blue
Rodmiser is offline   Reply With Quote
Old May 4th, 2017, 08:45   #410
ntwrkd
TDI(s): Jetta TDI
2011: (16 cars)
2012: (22 cars)
2013: (22 cars)
2014: (14 cars)
355 mi
2015: (7 cars)
39,856 mi 05/04/17 ntwrkd v.: sel 6mt owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: purchased 4/08/15 44.9mpg best tank 48.7mpg
ntwrkd is offline   Reply With Quote
Old May 21st, 2017, 21:02   #411
NeoZipTDI
2011: (17 cars)
118,000 mi 005/21/17 NeoZipTDI v.: 6mt bse owner: 1 tb: 1 dpf: 2 hpfp: 1 ef: 1 fb: 2 rb: 2 note: replaced intake manifold near 110k miles
2012: (22 cars)
2013: (22 cars)
2014: (14 cars)
355 mi
2015: (7 cars)
NeoZipTDI is offline   Reply With Quote
Old November 16th, 2017, 11:09   #412
16vjohn
2011: (17 cars)
2012: (22 cars)
2013: (22 cars)
2014: (14 cars)
355 mi
2015: (7 cars)
32,100 mi 01/10/17 16vjohn v.: 6MT BSE owner: 1 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note: Purchased 3/20/15, 46.1mpg
15 Jetta TDI 37k // 11 Ford Fusion
Retired: 13 Passat, Buyback // 01 Jetta TDI 177k // 98 Jetta TDI 291k // 00 Jetta TDI 240k // 91 300D 2.5T // 90 Jetta TD
16vjohn is offline   Reply With Quote
Old December 14th, 2017, 21:06   #413
SnieselDiesel
SnieselDiesel's Avatar
Fuel Economy: 54, 43, 48
2011: (17 cars)
2012: (22 cars)
84,500 mi 12/14/17 snieseldiesel v.: 6mt owner: 2 tb: 1 dpf: 1 hpfp: 1 ef: 1 fb: 1 rb: 1 note:
83,000 mi
2013: (22 cars)
2014: (14 cars)
355 mi
2015: (7 cars)
2012 Jetta TDI 6MT - 84k miles
Sold - 2003 Jetta TDI
SnieselDiesel is offline   Reply With Quote
AZNWHIP's 2011 CW Mk6 TDI Build Thread aznwhip VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 166 September 16th, 2014 20:35
May 2013 Mileage Thread Juergs TDI Fuel Economy 118 June 8th, 2013 16:59
The "What did you pay for your Mk6 Jetta TDI" thread ~Jb VW MKVI-A6 Jetta Sedan (~ 2011+) 126 November 8th, 2012 15:23
WTT: Portos (MK6 Golf) for Mambos (MK6 Jetta) dean_park Private TDI Items for Sale/Wanted 7 July 29th, 2012 19:59
May 2010 Mileage Thread Juergs TDI Fuel Economy 129 June 7th, 2010 06:02
Page generated in 1.12930 seconds with 11 queries
[Output: 421.99 Kb. compressed to 409.44 Kb. by saving 12.55 Kb. (2.97%)]
