Old February 19th, 2009, 08:42   #1
MadDogBrenner
Default Help, Odometer, trip odometer and clock blank and run car
Hi everyone,
I thought I would try to run a problem past any of you out there since I'm stymied. I just got the glowplugs replaced and some recall service done at the dealership. I also recently changed the air filter myself.
Service Friday, air filter Saturday.
Monday, I got in my car and the clock, trip odometer and odometer were all messed up. Only showing some of the lcd display. When I turned the key to let the glowplugs do their thing, no lights but the battery and engine lights showed up and it turned over but didn't run.
I figured something with the electrical may have messed up, so I took off, then connected the battery cables together to discarge any capacitance in the system. After this, the lcd displays were blank and the car acted the same way.
The only thing I have found on the internet that shows the same problem says that I should replace the ect sensor (I had to look it up, it stands for Engine Coolent Temp sensor). I got one yesterday and replaced it. No difference... except I made a nice mess with all of my engine coolant on the driveway.
Thanks for your time,
MadDog
MadDogBrenner is offline   Reply With Quote
Old February 19th, 2009, 15:28   #2
fossill
TDI(s): Golf
check fuses and relay 109?
fossill is offline   Reply With Quote
Old February 19th, 2009, 15:33   #3
MOGolf
MOGolf's Avatar
What "recall service"?
I wonder if the dealership is one that frequently supplies oilhammer with opportunities to repair after their workmanship.
MOGolf is offline   Reply With Quote
Page generated in 0.12696 seconds with 10 queries
[Output: 53.06 Kb. compressed to 47.96 Kb. by saving 5.11 Kb. (9.62%)]
