Old July 1st, 2017, 18:57   #76
Lightflyer1
Lightflyer1's Avatar
Well that explains it!
2015 Beetle TDI.
Old July 1st, 2017, 21:22   #77
aja8888
aja8888's Avatar
Fuel Economy: About as good as it gets!
Everything comes from China anymore so nothing is forward or backward compatible.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Bring the 1971 Beetle back to life thread:
http://forums.tdiclub.com/showthread.php?t=472400
aja8888 is online now   Reply With Quote
Old July 2nd, 2017, 00:05   #78
pkhoury
That guy with the goats
pkhoury's Avatar
Fuel Economy: CR - 36-41, PD - 39-48 (26-32 while towing)
And you have to use Chinese air with Chinese tires, otherwise you void the warranty. Oddly, it seems American air is compatible with European tires, but not the other way around.
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old July 2nd, 2017, 07:22   #79
turbobrick240
turbobrick240's Avatar
I've actually found that the air from China, Maine (my hometown)works acceptably well in Chinese tires. It does help to have a Chinese compressor though. I recommend inflating to 1776 torr when using Chinese tires.
Old July 2nd, 2017, 08:06   #80
pdq import repair
Fuel Economy: 38.5
Back on topic. Modern blinker fluids all have a weight penalty. You can use the old British racing standard to lighten your car and thus increase horsepower to weight ratio.
The British systems even today use smoke instead of fluid. it is much lighter and faster acting than fluid based systems. Leakage can be an issue with the lighter consistency of smoke so you may have to replace the seals with proper leather ones.
I believe the chinese have come up with a simulated real leather imitation that is an exact color match to the original.
pdq import repair is offline   Reply With Quote
Old July 2nd, 2017, 08:10   #81
pkhoury
pkhoury's Avatar
So would a simulated real leather imitation be an imitation of an imitation?
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old July 2nd, 2017, 08:15   #82
pdq import repair
Fuel Economy: 38.5
Yes that is the Chinese standard. Sometimes for good measure they go one imitation further in copying.
Got to admit though, color match is usually very good.
Old July 2nd, 2017, 12:27   #83
pkhoury
pkhoury's Avatar
Speaking of which, I heard KaleCo blinker fluid is now made in China. Can anyone confirm?
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old July 15th, 2017, 06:17   #84
pdq import repair
Fuel Economy: 38.5
Oh. I hope not. That would be a blow to enviros like me. If I remember correctly, the kale part of their name came from the using natural kale derivatives.
Synthetic stuff is desirable to many people but I prefer organic and simple. I can't get myself to use synthetic oil on my common rail even for fear of cancer risk. I stick with straight 30 weight non-detergent oil there.
I realize my cancer risk is small not living in California but, you can't be too careful anymore.
Page generated in 0.15927 seconds with 10 queries
[Output: 93.36 Kb. compressed to 80.03 Kb. by saving 13.33 Kb. (14.28%)]
