Old July 13th, 2017, 13:27   #1
mwmclelland15
Default Questions - 2006 BRM MKV - EGR Delete + Tune
Good day,
I currently have a 2006 Jetta TDI 5 Speed that has recently started the famous EGR cooler "hiss". Instead of throwing another cooler in I am looking at buying a "delete" kit. I have heard good this about this kit here: http://www.fixmyvw.com/brm-egr-coole...it-by-buzzken/
Before I get into the questions I should mention I live in Ontario and I do not need to pass an emissions test where I am.
Q. I was recommended to install a Malone tune stage 1.5 however I would like others inputs. This would require me to either purchase the "Flashzilla" or rent it on top of purchasing the tune. Do I need to purchase the stage 1.5 tune or just the below $90 "EGR Delete" tune.
Q. Any recommendations away from the kit in the above link?
Thanks ahead of time!
mwmclelland15 is offline   Reply With Quote
Old July 13th, 2017, 14:07   #2
relumalutan
relumalutan's Avatar
Install the delete kit and buy a Malone 1.5 tune. It really brings the car to life, and slightly improves MPGs.
relumalutan is offline   Reply With Quote
Old July 13th, 2017, 14:23   #3
h4vok
h4vok's Avatar
Doesn't that kit retain the egr just deletes the cooler? If that is the case no need for tune if you don't want one. If you are going to fully delete it though I would just go all in and rent the flashzilla and do a stage 1 or 1.5 with egr delete and dynamic idle too since you are in canada. If you keep the egr though you can do the dynamic egr which is a nice alternative.
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is offline   Reply With Quote
Old July 13th, 2017, 18:34   #4
Enabled
When you delete the cooler, you also block the exhaust recirculation flow, which will throw EGR codes, even if the EGR valve is present.
-2003 Jetta TDI GLS Manual (Daily beater. Mods: GLI Springs/Koni Shocks, SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned) 47mpg at 80mph
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car) + BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon
Enabled is online now   Reply With Quote
Old July 17th, 2017, 12:07   #5
mwmclelland15
Thanks all for your help. Did some more research and talked to Malone Tuning and was pointed in the direction I was originally heading, which is to install the "delete/block" kit and throw in a 1.5 tune.
Right now I will be running the car for a couple weeks as is. I'll post what my results are.
Old July 18th, 2017, 04:48   #6
scrambld
Just an FYI for you. I had a Malone Stg2 in my otherwise stock '06 BRM Jetta/5spd. Absolutely LOVED it and no boost creep issue noted.....already had a VR6 clutch in it though (2* failed DMF).
scrambld is offline   Reply With Quote
Egr delete 2006 jetta BRM Zwelder81 VW MKV-A5 Golf/Jettas 20 November 28th, 2017 17:36
TDI BRM EGR Delete Complete. Questions tanner VW MKV-A5 Golf/Jettas 5 May 25th, 2017 07:57
EGR delete kit for 2006 BRM BioJetta2001 Private TDI Items for Sale/Wanted 8 May 7th, 2017 17:24
Passat B5.5 BHW - EGR Delete and Tune Questions kentonsj VW B5 Passat TDIs 20 August 27th, 2015 08:09
Page generated in 0.15075 seconds with 13 queries
[Output: 73.33 Kb. compressed to 64.21 Kb. by saving 9.13 Kb. (12.45%)]
