Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old July 15th, 2017, 18:10   #1
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Default Boost fluctations! (mod to move to a better section?)
This whole post has been re worked based on new info.
Still diagnosing boosting issues!
mods:
*EGR delete with race pipe/block off plate is the only mods, and the vacuum ball was removed. (and former vendor alh toyota swapper) did this work. It worked well.
*I did a karma tune, The n239 is tuned out, as is the n18 (i believe have not tested yet) no stored codes in vcds free version.
On to the processes
First i unplugged MAF cured limp mode,
so cleaned the maf which cured limp mode when plunged in
VCDS MAF readings were still low so per some suggestions elsewhere I replaced it.
Well the maf is working well now but the boost is still off, so it did not fix the issue.
I need to know how badly these boost numbers are breaking the turbo/engine.
Boost is still off in VCDS. What does the community thinK?
http://pics.tdiclub.com/showphoto.ph...e=vcds&cat=all
http://pics.tdiclub.com/showphoto.ph...e=vcds&cat=516
NEXT
after another nearly sleepless night of better understanding with lots of sifting and learning I tracked down somethings wrong mechanically....
I believe actuator is not working well, OR IS IT THE INTERNAL VEINS STICKING? I can't afford to throw money at this problem!
d.
see video below to see what I believe is causing the derivations between the requested and actual boost.
I don't wanna just pull the turbo, I can't just but an actuator and have it be the turbo vein lever or internals.
I guess the oven cleaner trick is my next bet?
https://www.youtube.com/watch?v=c3ra...m-upload_owner
This is clearly why the boost numbers don't match!
****Again how bad are the boost numbers (VCDS PICS above) for the turbo another components? ****
I lubed the actuator arm and moved it around. it still is loud and seems to be binding on something. I have not had a chance to drive since then.
thank you
Dennis
Last edited by dhangejr; July 17th, 2017 at 17:45. Reason: more has been revieled.
dhangejr is offline   Reply With Quote
Old July 15th, 2017, 18:12   #2
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Old July 15th, 2017, 18:21   #3
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Default trying advanced mode for excell sheet!
this "browse button" does not exist for me! only fo HTML documents
http://forums.tdiclub.com/faq.php?fa...chment_explain
Old July 17th, 2017, 10:42   #4
BobnOH
Fuel Economy: 50/45/35
You need to log in at pics.tdiclub.com, use the Upload function and harvest a link. Then post the link.
It's better to print the Excel file to a PDF or something.
Allowable file types, mpeg,mpg,avi,asf,wmv,mov,pdf,doc,xls,xlsx
Old July 17th, 2017, 17:46   #5
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Thank you BOB! I have done so. I think this thread should now be in a diffrent location. I don't wanna x post maybe a mod can move it?
Thank you community again.
I would never have bought this car with out this page!
Old July 19th, 2017, 01:52   #6
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Bump
I don't wanna repost in the proper section ,
But I think I'd get better response a elsewhere.
Initially it was a VCDS question but I've graduated
Old July 19th, 2017, 18:31   #7
eddieleephd
Fuel Economy: 45-51.9
You can drop the log in a Malone window and post the link here. Easier to see.
2003 Jetta Wagon Alh w/5spd swap, 11mm IP, VNT17, Malone stage4 tune, BMW Cyclonic CCV filter, 2" lift
eddieleephd is offline   Reply With Quote
Old July 19th, 2017, 18:37   #8
eddieleephd
Looks like one of three things.
Vacuum leak, n75 valve, or needs actuator adjustment.
When was the n75 changed last.
I would replace vacuum lines if the fibers crumble when touched, or the ends re cracking.
N75 seems expensive, however, a spare is nice if it's good.
Actuators wear and stop moving as well as they should.
Adjustment is kinda annoying, but, this doesn't have to be done often.
Remember to log 1500 to at least 4000 if not redline.
Drop the log in Malone website and post link.
This will help a lot!
Old July 19th, 2017, 19:29   #9
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
I'm on the road now, so I'll get back, but did you watch the video of the actuator too?
As soon as I get a chance (probably Wednesday of next week ) I'm gonna take the actuator off and test it that way. The hoses are all testing good when I plug one end and apply vaccume with my toung.
I think the n75 is hard to test! Lol
Thanks for the reply
Old July 21st, 2017, 01:58   #10
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Today, I hooked up VCDS and monitored 11 boost.
at idle request is 966 actual is 1009 ( something like this) its over boosting. So I went and pulled up on the lever that moves the veins attached to the actuator. Boost then leveled out! So sucked on the hose that connects to the actuator as to actuate it and back to over boosting. SO the actuator is either not able to push the vein lever back into place, OR the veins are stuck? Not so fast!
Next, I Re routed the hoses to eliminate the n18.
Boost (on my gauge) spikes to 18-20 and settles at 12 or 13. However the VCDS still reports slight over boost at idle. but 1500-4500 WOT 3rd gear runs show the boost is actually closer than it was before, in fact a few times it was SPOT on! Weird!
Before, on WOT tests it was spiking to 13 or 14 and settling in at 9 or 10 on the ugage and was slightly off and under boosting
Guess the N18 was bad? Im gonna replace the three hoses now and then see what happens. IF nothing, ill switch the n18 with the n75 and see what happens.
If nothing changes IE boost does not level out to normal than Ill probably get stupid and try a can of oven cleaner? IF no go ill adjust the actuator arm. Then and only then will I remove the turbo and clean it and replace the actuator. First ill check for shaft play onthe turbo tho. Which I need to do any way.
I need to keep searching and reading. THe more I read the same **** over and over (in different threads) the more ideas I get.
I wish this was in the right section and I was getting some other ideas here other than my own! sometimes my ideas suck!
Old July 22nd, 2017, 20:22   #11
eddieleephd
Up to 150 over is good. Actuator seems adjused well. N75 or actuator if it doesn't move easily.
Old July 24th, 2017, 00:01   #12
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Well in constantly under boost! No good! I'm not sure about this "moves easily" mine seems to make a creaking noise st the end. Pretty sure it's gonna get replaced. They a safe part to get used local guy has one that is basically new so he says and it looks good too
Old August 3rd, 2017, 21:25   #13
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Well, swapped n75 for n18.
N75 dropped pressure fast with vac, n18 help pressure a bit longer.
Boost now spikes to 20 but still only holding at 12-14 I have one vcds log on to follow.
Being the boost requested vs actual is only off by 140 at the most I don't think it's the actuator adjustment. Maybe the pieces inside are rusty tho. It makes some noise.
I tested al the vaccume hose and they all hold -25" reliably. I'm replacing them soon becaUe one is frayed, so it's cheap Insirance.
I'm frustrated and on a budget.
My biggest question relates to the above statement about boost being off by 150 over being good. What about 150 under?
Perhaps my boost guage is the problem , I did take it apart when I got it .
Old August 4th, 2017, 10:16   #14
eddieleephd
150 under isn't so bad. I would recommend adjusting to 150 over if you are experiencing low boost issues though.
Logging is the only way to tell though.
Post a couple sequential logs and we might see what you need.
Can't say much without the numbers to compare.
Max boost at 20 and holding at 14-15 isn't bad depending on the tune.
If it's tuned to boost at 22 and you're only getting 20 then it's probably the adjustment, or the control components.
Old August 4th, 2017, 11:08   #15
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Here's a video and a log from yesterday
A few sequential logs from a few weeks ago
http://pics.tdiclub.com/showphoto.ph...5f3924&cat=500
Looks like the video does not work
Here is what the boost guage is doing.
I'll do more logs soon. VCDS Is Showing s max of 150 underboost. It is pretty close, if the boost guage was not wonky I'd not even care , but Charlie said my tune should look like this
"3000 rpm = 17.4 psi
3500 rpm = 17 psi
4000 rpm = 16.6 psi
4500 rpm = 14.5 psi"
Here's what it's doing now, before I swapped for the n18 it was only spiking to 18 and then holding about the same
https://youtu.be/5GkN3SJ7r1w
Limp mode ... new everything, and still limp! big_worm81 VW MKIII-A3/B4 TDIs 7 November 18th, 2016 08:36
Limp Mode VWJetta2006 TDI 101 1 May 12th, 2015 20:49
Limp Mode; HELP!! golf.angers TDI 101 1 February 26th, 2015 20:08
Transmission in limp mode - how to reset / remove limp mode? nvr-enuf VW B5 Passat TDIs 7 August 26th, 2013 04:18
Possible limp mode? Rob71zilla TDI 101 7 January 7th, 2012 11:07
Page generated in 0.17091 seconds with 13 queries
[Output: 127.51 Kb. compressed to 106.05 Kb. by saving 21.46 Kb. (16.83%)]
