BearForceOne
Relevant info:
2001 02J ALH Jetta sedan
349k miles
New VR6 clutch/SMF conversion
Since I bought my Jetta in late August with 343k miles, any time I've started from a stop the whole car shakes pretty significantly, enough to make me believe it's not normal and acceptable NVH from the factory. No matter how much fuel I give it, how quickly or slowly I let off the clutch, there's always a moment of intense vibrations. There is no issue shifting gears when in motion, just when letting off the clutch while in first from a stop or very low speed.
Initially I believed it to be a bad dual-mass flywheel, which I found was very loose and needed replacement, but was not the cause of the vibrations. Next was a replacement driver's side engine/trans mount, and dogbone mount as both had a lot of miles on them and were notably loose. These improved the feel of the car a little, but the vibration still continues.
I'm running out of guesses as to what could be causing this, and it's really starting to get on my nerves. Perhaps my Google-fu isn't as great as I'd like to think it is, but I've been unable to find any related threads on the forum or posts online with similar symptoms.
Am I grasping at straws that it might be a CV shaft or transmission issue? Or maybe the fuel filter is plugged and the engine is being starved of fuel on launch? There is a notable amount of bubbles in the feed line between the filter and injection pump.
Any help is greatly appreciated, thank you!
349k miles
