Hi, I've got a 99.5 alh tdi that starts when dead cold but won't when left warm for a while.
16764 - Glow Plug/Heater (Q6) Circuit: Malfunction
P0380 - 35-10 - - - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
17654 - Needle Lift Sensor (G80): Implausible Signal
P1246 - 35-00 - -
There is a glowplug out - first code. Checked w/ vag-com while cranking and there is no rpm reading but I do get a pedal position reading if I step on the accelerator - so ecu has power so not the 109 relay/ignition switch? I tried a crank sensor but it did not help.
Any reply would be appreciated.
P1246 - 35-00 - -
