TDIsweden
This is going to be a long text and im from Sweden so probably some bad english as well... be patient with me here.
I need some help with my golf TDI ALH engine, manual transmission. I dont get the "choo" sound when I change gear/let go of the gas pedal..
When I bought it there were an error code that said overboost and the car went into limpmode when you floored it.
Changed the VNT actuator because it was leaking and adjusted the rod to 18inhg.
The car was still overboosting and the boost was going up to 2bar+ and then down to around 1.5bar.
Today I changed the turbo to a refurbished one from ebay, german company, no china! Everything went fine, now I have a normal working turbo with good boost. Peaks 18psi and then it goes down to around 14-15psi.
BUT, still no sound!?
I do have one fault code left on the fuel temp sensor. But I dont think a faulty fuel temp sensor can mess with the turbo noise... I belive the code is there because of the evrymod? I have a new sensor but waiting for the special socket tool I need to open the injection pump.
Other things that I have done to the car:
• changed all vacuum hoses, MAF sensor, MAP sensor, intercooler and n75.
• Evry mod, no difference between on/off.
• 2.25" straight pipe from turbo with 3" side dump, no cat. It is an aftermarket dp but no sound with original dp either.
• Egr delete
• Checked the vacuum pressure, around 25inhg on idle.
• Leak tested all the hoses/pipes and intercooler with smoke machine. No leaks.
Can someone please try to help me figure out why the turbo doesnt make the lovley chooo sound!
Link to a video that shows what sound im after!
https://youtu.be/VfQL8pcT_uU
• Egr delete
