Fortuna Wolf
You think it would be simple...
The front bushing is held in with an 18mm bolt right behind the automatic transmission pan. I had to use an open ended wrench to loosen it, and then when I try to pull the bolt out, i pull it into the ATF pan, and I'm like... uh... I'm -not- going to change my ATF just to replace this bushing.
Also, the rear bushing's bolt has a nut on the other end, so now that its loose its just spinning. I can't figure out how to get a wrench in there (its very tight) to hold the nut while I remove the bolt. Any hints?
