Nero Morg
Firestone does. Sometimes they'll run a promo and its $170, normal. Price is #220 if I remember right.Who sells a lifetime alignment?
I've spent enough on them over the years, would love to have paid it once.
Isn't that where a road kill goes for a ride in or on the front of the car???Toad in...
I think that winds hung up in the splits of the fender liners. Moral of the story: replace them when a crack appears.Isn't that where a road kill goes for a ride in or on the front of the car???
Cheers,
PH
I haven't on the tdi yet, but have on several other engines including my MKIV 2.0 8v gasser (AEG). You'll need some means to remove the old seal, I've successfully used a pair of paint can keys, working end wrapped in scotch tape to avoid scratches on the crankshaft snout. If you have access to the proper tool for the task, that's preferable. For installation I've used an appropriate diameter socket and washers with a longer bolt into the crank snout to pull the new seal into place. Use the plastic guide the seal ships on, unless the directions say otherwise, and be prepared to leave it alone for 24 hours or the specified time period before moving the crankshaft.Has anyone replaced the FRONT crank shaft seal? Should be in this area. What will it entail if so? I need to do my TB and I need to plan accordingly. I’m thinking I can combine this work along with the TB work.
I have. Need to replace the big bolt, and seal. The bottom part is actually the seal carrier, it comes off the engine. I'd suggest cleaning and re-siliconing it. Behind it is the chain for the oil pump. If you're feeling adventurous you could upgrade the pump for better cold start oil pressures. Requires taking off the oil pan.Has anyone replaced the FRONT crank shaft seal? Should be in this area. What will it entail if so? I need to do my TB and I need to plan accordingly. I’m thinking I can combine this work along with the TB work.
What is the proper tool for this? I’ve seen a tool from metalnerd I think that counter holds the crank pulley but not one for the actual seal.You'll need some means to remove the old seal, I've successfully used a pair of paint can keys, working end wrapped in scotch tape to avoid scratches on the crankshaft snout. If you have access to the proper tool for the task, that's preferable. For installation I've used an appropriate diameter socket and washers with a longer bolt into the crank snout to pull the new seal into place. Use the plastic guide the seal ships on, unless the directions say otherwise, and be prepared to leave it alone for 24 hours or the specified time period before moving the crankshaft.
The seal change didn't add too much complexity to the timing belt change in the instances I've performed it.
If you pull the seal carrier off, just press in a new seal until it's flush.What is the proper tool for this? I’ve seen a tool from metalnerd I think that counter holds the crank pulley but not one for the actual seal.
Wow! This is the one to go with!! Check this outLisle 58430 is an example of one type of seal puller that works similarly to the paint can key method, slipping a curved finger between the seal and crankshaft.
The guy in that video! "I don't know if I'm using it correctly, but I already love it" LOL - that's me and every tool I've bought=BakoTDI;5545806]Wow! This is the one to go with!! Check this out
https://youtu.be/YrVwf6BHLTw
What have you used to lube the new seal?
Dry in many cases. All of PTFE/Teflon lined cam/crank shaft gaskets I have encountered have come with instructions to be installed without any lube. New seal should come with some brief instruction from the manufacturer what to do.What have you used to lube the new seal?
I have had the west marine oil extractor for several years now. I even use it on my old Atomic 4 engine in my sailboat. Works great. Even with no maintenance of it and just chucking into the back of the shed every time I am done with it.Purchased an oil service kit from IDPARTS, where I buy all my service kits. I also purchased an oil extractor from West Marine.
