Deep Fried
My wife drove my TDI '01 golf and when I got in, the steering wheel was cocked at a 45 degree to the left as the car drives straight.
I thought maybe she had hit a curb or something.
However, as I drove it I didn't pull one way or other.
But, then I was making a very slow turn into a parking lot and making my first turn, I could feel the wheel "free slipping" (best way I can describe) like the wheel was free-spinning for a portion of the turn and then suddenly the wheel "caught" and I was able to complete the first turn. Then I turned back the other way and, hell, it did it again... While the wheel "slips" the tires do not turn - the car continues move straight - if I don't brake it would head off the road or whatever tangent I happen to be headed for... then when it 'catches' the tires turn as they should
The wheel was then totally upside down when in the 'straight' position.
Later, the car was parked and I had my radio on for quite a while and my battery ran low. I was parked on a hill. I tried to push start but needed to turn it to the left to head the car downhill. The steering wheel just spun in place and wheels would not budge... it started raining really hard so don't know if moisture enhanced this problem or not... I had to rock the car back and forth while trying to turn the wheel. It finally turned enough to get the car rolling and bump-started it.
I felt the wheel slip a few other times as I made turns. This is really dangerous but before I take it to a mechanic I want to know if anyone can diagnose the issue... I do know that when I purchased the car the steering wheel has always had "play" - not left/right but forward-backward play..
I can push/pull the steering and it has a good bit of play... could it be as simple as the nut that holds the wheel on is loose?
or some other issue?
thanks!
Deep Fried
thanks!
Deep Fried
