Joe Bitsko
My 96 TDI is burning oil (one quart in 60 miles) smoking badly. The cylinder compression is 500 pounds straight across(all four). The turbo was just replaced 200 miles ago. Lots of crankcase pressure. The turbo appears to be tight (feeling normal at intake side). I installed a quater inch copper line to supply oil to the turbo. The previous line fed from the end of the camshaft(low oil pressure there)oil pressure in engine is 10 pounds at idle hot and 28 pounds at freeway speeds, seems low to me. the oil pressure at the camshaft is only 10 pounds at freeway speeds, five pounds at idle. This is the third turbo in 1000 miles. I am thinking my bearings at the mains (original) are worn badly and lack of oil pressure is killing the turbos. Power is low as well. Rings were replaced two turbos ago. Pistons looked good. Taper in the cylinder was only .002. Any comments out there in TDI land? Thanks
Joe
Joe
