ajaxstar
- Joined
- Oct 18, 2014
- Location
- WI
- TDI
- MK3 TDI Jetta (being parted out) MK4 Jetta (sold) 96 B4 Passat Wagon
I'm continuing to hunt for a Passat or Jetta Wagon and have come across a 2004 5 speed automatic w/ OD Passat Wagon with 131k for $4000. This is what has been replaced recently by the current owner who has had the car since 2010.
Tires
Boost control solenoid
Timing belt
Front outer CV boots (both)
Front axles (both)
Alternator clutch ASSM
Rear brakes & rotors
I am concerned about the known transmission and balance shaft issues with these models as the owner has not done either of those repairs. The owner states that there is a small oil leak and a check engine light on (possibly due to an air flow gauge?-the owner could not give me a code number). The vehicle has reportedly been maintained by a VW expert near Duluth, MN.
Ideally it would be nice to have the car inspected by a trusted member, but I do not know if time will allow. I would appreciate any feedback/input as I have not yet gone to look at the vehicle.
Tires
Timing belt
Front axles (both)
