Audiman
I've got a Golf a 2004 MK5 1.9TDI that takes ages to start.
Checking the error code shows "P0341 Camshaft Position Sensor (G40)" code.
I had replaced the sensor, but still getting the same code - still takes long time to start. Still showing the same code even after clearing it.
So checking the wiring, ignition on
Wire 1 = 5v (live)
Wire 2 = 5v (Sensor signal)
Wire 3 = Ground (Earth)
I think the cabling looks ok - maybe it's a faulty new sensor OR maybe Wire 1 and Wire 2 are shorted ?
Anyone know if the voltages are okay ?
Also is there any diagram to show where these cable terminate at the ECU ?
Wire 1 = 5v (live)
