Don't forget to lube those bushings...
20IndigoBlue02
Was North NJ, now SoCal
2002 Golf TDI-- deceased
Wingnut, of course has a nifty how-to on how to replace the swaybar bushings.
But, since mine are not clunking, instead I get a front-end squeak from suspension compression & rebound, and for the past week, more squeaking from steering while parking (which does load up the sway bars).... just a quick reminder... spray some silicone lube into the bushings every now and then when you go underneath the car for things such as oil changes.
I don't think a DIY is necessary... since Wingnut's how-to will tell you where to spray
mailman
USA - CT
99.5 Black Jetta TDI
Aren't the revised bushings impregnated with some sort of solid lubricant like talc or something?
