Bought a 2005 mk5 tdi Jetta used. Trying to fix all the little problem. Noticed the front drivers side turn indicator doesn't work. So I thought. Someone had just turned it so it wouldn't run down battery. It also doesn't blink. When you have it plugged in, the key fob will not blink any lights. When you unplug key fob blinks lights. Any suggestions where to start? Thanks
