I’m having strange low power issue which I’m trying to figure out. Hopefully you guys could help me on this. Car is 2005 VW Touran (which is based on Golf MK5), whith 1.9tdi PD105 engine. Engine code is BKC.
Symptoms are:
Following vw service manual I replaced tandem pump with brand new Bosch unit, but it didn’t solve the problem. Next thing vw service manual suggest is changing injector o rings, but I'm really not so sure that this could be the reason...
Fuel filter also has been changed recently.
Any suggestion what else to check/replace? In tank pump (lift pump)?
Any help appreciated.
Symptoms are:
- Car has very low low end power. Power starts to kick in at only around 2300rpm.
- There are no fault codes.
- Things get worse when engine fully warms up.
- Engine has some power while it is half-warm, but as soon as engine reaches 90 degrees Celsius things become real bad. Idle fuel consumption goes up from 0.5l/h to 0.7l/h (in hot days when using AC it goes up even to 1-1,1 l/h and I also have to rev engine up before starting to drive, otherwise it would cut out).
- With warm engine there is very noticeable lag (1-2 seconds) when pressing accelerator pedal. And it’s impossible to floor it when warm because engine starts to buck severely. Basically you have to keep gas pedal no more than half pressed to avoid this happening.
- Engine starts OK, both hot and cold.
- Fuel consumption is OK, maybe slightly higher than normal, but nothing to be concerned about.
