I am putting taller tires (205/70R15) on my '03 Jetta and also want to put in a taller 5th gear (.681 or possibly .658) the combination will lower 55 mph rpm to about 1700. I would like to lower the point of peak torque to around 1700 rpm. Anyone know of any modifications to accomplish this? Also anyone that has put the taller gears in want to share their experience with mpg gains and drive ability after the gear change?
Mike, I understand putting taller tires on and going to a longer 5th gear. I have been there, done that.
I am running 195/65x15 tires in place of 195/60x 14 (note 15 inch wheels vs 14 inch wheels). I am also running a EuroTuning 6 speed conversion that adds a 6th gear to my stock 5 speed. Lastly, my transmission has a 3.157 final drive, while your transmission has something like a 3.39 final drive.
I am actually running about 1900 rpm at 70/72 mph in 6th gear.
You do not want to lower the rpm for peak torque. What you want is more torque at 1700 than you have now.
For that you need larger nozzles and a tune. Take a look at my signature, you will see I am up 50% in low end torque compared to stock. All I did was install larger nozzles and get a tune. With that I can pull the bigger tires and the .59 6th gear and still climb any grade on the interstate highway system. Last Sunday, I had no problems sustaining 70 mph going from Sacramento to Reno, over the 7250 ft. Donner Pass.
